Change Management in IT Service Management: Controlling changes securely and efficiently
Change Management creates the prerequisites for implementing changes to productive IT services in a controlled manner. Traceable risks, appropriate approvals, reliable data, and verifiable results are crucial. We show you how experienced IT administrators and IT managers structure change requests, define responsibilities, and use a CMDB for resilient decisions. A practical example and concrete key performance indicators (KPIs) demonstrate how speed and operational stability can be improved together.
1. What does Change Management deliver in ongoing operations?
2. Change Management in ITSM and its classification in ITIL
3. Meaningfully distinguishing the three change types
4. What a resilient ITSM Change Request should contain
5. A practical process for ITSM Change Management
6. What tasks does the ITSM Change Manager perform?
7. ITSM Configuration Management as the basis for risk assessment
8. Practical example: Migrating a productive database
9. Best practices in Change Management for experienced teams
10. Which KPIs make quality visible?
11. Secure changes require resilient decisions
A database update is technically well prepared. Nevertheless, a business application subsequently fails because the new version is not supported. Such situations show: The quality of a change also depends on whether its impacts on dependent services are known.
Change Management controls changes throughout their entire lifecycle. This includes recording the initiative, assessing the impacts, authorization, scheduling, and post-implementation review. An ITSM change can affect applications, infrastructure, configurations, or operational procedures.
For IT managers, this creates a resilient basis for decision-making. Administrators gain clarity regarding prerequisites, responsibilities, and abort criteria. Integration into overarching IT service management with i-doit connects changes with services, responsibilities, and documented dependencies.
Everything on IT service management in our whitepaper
In this whitepaper, we guide you through 6 practical steps to successfully implement IT service management in your organization and reliably align your IT processes, systems, and services.
In ITIL 4, the corresponding practice is called Change Enablement. Its purpose is to facilitate successful changes through appropriate risk assessment, authorization, and schedule control.
For the practical design of Change Management in ITSM, a clear differentiation is helpful: Incident Management restores agreed-upon operations after a disruption. Problem Management investigates root causes and recurring errors. Any changes required as a result go through the appropriate evaluation and approval.
Release Management organizes the provision of new or changed services. Deployment Management deals with the transition of components into the target environment. Change Management provides the framework for deciding under what conditions a change may take place.
The alignment of ITIL and IT documentation helps to connect these tasks on a shared information basis. Organizational changes, such as the introduction of new management structures, additionally require targeted support for the people affected.
ITSM Change Management should align the inspection effort with risk, repeatability, and urgency. For this, the distinction between Standard Changes, Normal Changes, and Emergency Changes is helpful. The classification must be justified and comprehensible for the teams involved.
Standard Changes: repeatable and pre-authorized
A Standard Change is low-risk, understood, documented, and pre-authorized. The approval applies to a defined procedure under specified conditions. A possible candidate is the replacement of a redundant component according to a tested work instruction.
Frequent execution alone is not sufficient for this classification. If prerequisites, service criticality, or technical dependencies change, the applicability of the procedure must be re-examined. The individual executions should also be traceably recorded.
Normal Changes: evaluation according to risk
Normal Changes require individual evaluation and authorization. This can include, for example, the migration of a productive database. Which authority decides should depend on the specific risk and impacts.
A manageable intervention can be approved by a designated technical authority. For a change with cross-departmental impacts, additional coordination makes sense. A central body (e.g., CAB - Change Advisory Board) for every operation creates unnecessary waiting times.
Emergency Changes: accelerated and traceable
Emergency Changes must be implemented quickly, for instance, to resolve a severe disruption or to fend off an acute threat. An accessible decision-making authority, a shortened evaluation path, and clearly regulated follow-up processing are recommended.
Document which checks were possible prior to implementation and which will be completed afterwards. ITSM Change Management should also investigate whether recurring emergency changes point to avoidable deficits in planning or maintenance.
A Change Request must enable a decision. Technical depth is required where it makes impacts, feasibility, or recovery traceable. Extensive free text without verifiable statements complicates the evaluation.
For productive changes, a structured data record with the following contents is recommended:
Goal and reason: Expected benefit, business sponsor, and consequences of a postponement.
Scope: Affected services and Configuration Items with clear references.
Risk and impacts: Potential disruptions, affected users, data risks, and technical dependencies.
Implementation plan: Work steps, sequence, prerequisites, responsibilities, and required access rights.
Test plan: Test results, technical controls, and measurable business acceptance criteria.
Fallback strategy: Recovery path, required time, and binding abort criteria.
Schedule and communication: Maintenance window, potential overlaps, and stakeholders to be informed.
Decision and result: Approval, conditions, actual progress, and references to evidence.
The ITSM Change Request should record planned and actually executed steps separately. If there is a deviation from the approved scope during implementation, a defined decision regarding continuation, re-approval, or abort is required.
1. Record and qualify
Check the goal, completeness, and change type. Appoint a responsible person for the implementation and link existing incidents or problems. Missing information should become visible early on, before resources are reserved for a maintenance window.
2. Assess impacts and risk
Consider the probability of occurrence and the extent of damage as well as practical recoverability. A minor configuration change can harbor high risks if it affects a central authentication service. Conversely, a more extensive change in an isolated environment can be easily manageable.
Additionally, evaluate the uncertainty of the data foundation. Unknown dependencies or outdated operational information should trigger additional checks. A calculated risk score does not replace a comprehensible technical justification.
3. Authorize and schedule
The responsible Change Authority decides based on the available information. Approvals should refer to a clear scope and include any conditions. Check parallel ongoing work on shared infrastructure components as well as business blackout periods.
ITSM Change Management requires realistic time planning for this. The maintenance window includes implementation, functional testing, and a sufficient reserve for recovery. The latest possible time for a fallback must be determined before starting.
4. Implement and monitor
Work according to the approved process and record relevant deviations. In addition to technical states, also monitor the affected service. An accessible server does not confirm that users can successfully execute their business processes.
5. Accept and close
Closure takes place according to the agreed success criteria and a suitable observation period. Add test results, update affected configuration data, and link any disruptions that occurred. For failed or particularly high-risk initiatives, a targeted Post Implementation Review is recommended.
The ITSM Change Manager coordinates the regulated process, supports the quality of the requests, and ensures transparent communication. The role should clarify decision-making paths and make conflicts visible in the calendar.
Authorization is granted by the designated Change Authority. Depending on the organization and change model, tasks may merge. Responsibilities and any necessary segregation of duties must be explicitly regulated in advance.
For operational collaboration, the following division is recommended:
Requester: Describes the goal, benefit, and requirements.
Implementation manager: Plans the technical execution, testing, and recovery.
Service Owner: Assesses the impacts on the responsible service.
Change Authority: Authorizes the change within the assigned decision-making framework.
ITSM Change Manager: Coordinates the process, schedules, communication, and improvements.
A Change Advisory Board (CAB) can provide expert advice and resolve conflicts for complex initiatives. Whether it also grants approvals depends on the established decision-making authority. For ITSM Change Management, what counts is that the stakeholders know their responsibilities prior to implementation.
ITSM Configuration Management provides information about Configuration Items and their relationships. The impact analysis needs exactly these connections: Which applications depend on a database? Which services use the same network component? Who can confirm the business function?
The official description of ITIL Service Configuration Management emphasizes the availability of reliable configuration information. A CMDB supports this task when data maintenance, responsibilities, and quality controls are bindingly regulated.
With the i-doit CMDB, components, services, and their relationships can be documented. The CMDB Explorer visualizes existing dependencies. This allows stakeholders to investigate the documented impacts of a planned change more specifically.
Change Management benefits from this especially with shared resources. However, the visible scope of the analysis remains dependent on the maintained database. Missing relationships must be treated as uncertainty and, if necessary, verified with the responsible teams.
For the interaction with Configuration Management, a clear rule is recommended: Before approval, the relevant initial state is checked. After implementation, the actual state achieved is documented. Unique object identifiers connect the request, technical evidence, and configuration data.
Structured IT documentation with i-doit forms a common basis for this. Approval workflows and execution steps must be designed depending on the process solution used and its integration. A history of documentation changes supplements the business evidence of decisions.
A company is planning to migrate a database to a new version (major). Several business applications access it. For this example, the initiative is treated as a “Normal Change” because compatibility and recovery must be evaluated individually.
The ITSM Change Request references the database, the dependent applications, and the affected services. The technical managers check drivers, interfaces, backup procedures, and background processing. Business contacts define representative test cases.
A complete dry run provides reliable times for migration and recovery. In the case of a change in data format, rolling back the application might not be sufficient. Therefore, it is also clarified how data generated during the transition will be handled.
Suppose the maintenance window ends at 11:00 PM and the tested recovery, including testing, takes 45 minutes. With an additional 15 minutes in reserve, the decision regarding the fallback must be made by 10:00 PM at the latest. This is a binding control point in the process.
Following the transition, the stakeholders check login, data access, and relevant business transactions. Time-delayed processing is monitored during the agreed observation period. ITSM Change Management brings together this evidence with the approval, result, and updated configuration status.
Effective ITSM Change Management best practices reduce uncertainty and unnecessary effort. The following measures can be specifically integrated into existing operational processes.
Keep changes manageable
Limit the scope of an initiative to steps that belong together logically in terms of business and technology. Independent changes in the same maintenance window complicate root cause analysis. Tightly coupled steps, on the other hand, require a joint process with clear control points.
Tie approvals to resilient conditions
Define when test results, data quality, or recovery evidence are sufficient for a decision. Phrases like "backup available" are too imprecise. More meaningful are the time, scope, recoverability, and documented duration of the last suitable test.
Make automation traceable
Automate recurring checks and the transfer of secured results. Record which approved version of a work instruction or script was executed. Technical execution logs should be clearly assignable to the respective change.
Regularly review standard procedures
Change Management best practices also include reviewing pre-authorizations in the event of new risks. Failed executions, altered dependencies, or new requirements may necessitate an adjustment of the procedure.
Change Management should be evaluated based on jointly defined results. The number of completed operations alone says little about quality or business value. A manageable set of key figures is suitable for getting started.
| KPI | Possible definition | Benefit for control |
| Success rate | Successful changes divided by all implemented changes in the considered period. | Evaluate success based on fulfilled acceptance criteria and a defined observation period. |
| Error rate | Changes with a defined operational impairment, fallback, or unplanned rework divided by all implemented changes. | Evaluate error classes separately and take affected services into account. |
| Lead time | Time from the complete request to implementation. | Separate waiting times from active processing and compare by change type. |
| Share of emergency changes | Implemented emergency changes divided by all implemented changes. | Investigate causes for urgency and identify recurring patterns. |
| Documentation quality |
Completed changes with verified updating of relevant configuration data divided by all completed changes. | Check the connection between implementation and maintained operational knowledge. |
Before the evaluation, define how partial successes, aborts, and connected operations will be handled. Success rate and error rate only add up to 100 percent with correspondingly coordinated definitions. Recommendations for measurement should be adapted to your own operations.
The ITSM Change Manager can discuss these results regularly with the teams involved. Long waiting times point to different improvement opportunities than frequent fallbacks. ITSM Change Management is thus further developed based on concrete bottlenecks.
In IT Service Management, Change Management combines technical preparation, clear responsibility, and verifiable results. The crucial prerequisites are suitable change models, meaningful requests, traceable approvals, and a realistic fallback strategy.
A well-maintained CMDB provides the necessary context regarding services and dependencies. Together with appropriate KPIs and regular follow-up processing, a process is created that makes changes more plannable and specifically improves operations.
