IT infrastructure: planning, optimisation & best practices
1. What is an IT infrastructure? Definition and relevance
2. IT infrastructure structure: the three main components
3. Why is structured IT infrastructure planning important?
4. Best practices for greater efficiency and resilience
5. The role of IT documentation for a stable infrastructure
6. Infrastructure management software: solutions for maximum transparency
7. i-doit INDITOR®: support for planning, operation, and further development
8. IT infrastructure: foundation for stability and growth
IT infrastructure optimisation: from a cost factor to a strategic asset
IT infrastructures are under enormous pressure today: systems must be available at all times, services must function reliably, and data must be processed securely. If a disruption does occur, it quickly becomes clear how relevant up-to-date and structured IT documentation is. After all, a modern IT infrastructure consists of far more than hardware, software, and network components. It is, in fact, a complex overall system.
What does the structure of an IT infrastructure mean in concrete terms? And how can an IT infrastructure be planned and documented in such a way that it does not only run stably but also agilely supports future growth? In this article, you will learn how to strategically develop your IT infrastructure, design it more efficiently through targeted optimisation, and make it manageable over the long term with dynamic, automated documentation.
Free trial period of i-doit
Would you like to convince yourself directly of the benefits of i-doit? Then try our software for 30 days for free.
The IT infrastructure definition encompasses the entirety of all hardware, software, and network components required for the operation and provision of IT services. It forms the technical foundation upon which all digital business processes are built, from email communication and ERP systems to cloud-native applications.
A professional IT infrastructure comprises far more than just servers and workstations. It includes data centres, network components such as switches and firewalls, operating systems, data storage (SAN, NAS), security systems, and a wide range of software applications. The central premise is: only when all components of the IT infrastructure work together smoothly can companies achieve their business goals efficiently.
In recent years, the IT infrastructure has changed significantly. Instead of purely traditional on-premises solutions, companies today are increasingly relying on hybrid and multi-cloud models. These combine local systems with the flexibility of IaaS, PaaS, and SaaS solutions, which allows for greater scalability but also increases complexity in management and monitoring.
The structure of an IT infrastructure is divided into three central areas that are closely intertwined: hardware, software, and network technology form the foundation on which all IT services run. Only through the interplay of these components is a powerful, scalable, and secure IT environment created.
Hardware components
Hardware forms the physical foundation. This includes servers (rack, blade, HCI), workstations, mobile endpoints, and storage systems (SAN, NAS). The data centre infrastructure also counts towards this, including racks, redundant power supplies (UPS, emergency power generators), air conditioning, and structured cabling.
Software components
Software is the operational heart of every IT infrastructure. This begins with the operating system and the hypervisors (e.g. VMware vSphere) that enable virtualisation. Building upon this are application software (ERP, CRM), databases, container platforms like Kubernetes, and a broad spectrum of security software (endpoint protection, SIEM, backup).
Network infrastructure
The network component guarantees communication between all elements. It encompasses LAN, WAN, WLAN, the internet connection, and increasingly SD-WAN for flexible site networking, as well as VPNs for remote access. A crucial part is network security, which is realised through firewalls, IDS/IPS, and consistent network segmentation.
Well-thought-out IT infrastructure planning is the foundation of a resilient company. It ensures that all IT components work together smoothly and support business processes optimally. Without strategic IT infrastructure planning, significant risks threaten:
Lack of transparency leads to IT managers losing the overview. Without answers to questions about systems, versions, and dependencies, every disruption becomes an uncalculable crisis.
Inefficient resource utilization represents a financial burden. Unused licences or overdimensioned servers burden the budget. Structured IT infrastructure planning helps to deploy resources in a targeted manner and optimise costs.
Lack of scalability slows down growth. If the IT infrastructure is not flexible, new projects become a problem. Forward-looking planning creates the necessary agility.
Increased outage risks endanger operations. Without documented redundancies and emergency plans, minor disruptions can lead to long downtimes with significant economic consequences.
IT infrastructure optimisation for greater efficiency and resilience
IT infrastructure optimisation is a continuous process that combines technical and organisational measures. The following best practices have proven successful:
Utilise automation: The automation of data collection, patch management, or backups saves time, reduces errors, and increases the reliability of the entire IT infrastructure.
Conduct regular audits: Systematically check your IT infrastructure for outdated systems and security vulnerabilities. Audits provide the basis for decisions on IT infrastructure optimisation.
Establish monitoring: An effective monitoring system monitors performance and availability in real-time in order to detect problems early on before they lead to outages.
Consolidate resources: Virtualisation and containerisation make it possible to use hardware more efficiently and reduce operating costs. This is a central aspect of any IT infrastructure optimisation.
Evaluate cloud strategies: Critically examine which workloads are suitable for the cloud and which should rather remain on-premises for reasons of latency, security, or cost.
Detailed and dynamic IT documentation is indispensable for the successful operation of your IT infrastructure. It creates transparency, facilitates troubleshooting, and forms the basis for decisions during changes and audits. Structured documentation answers critical questions in seconds and makes it possible to react faster to disruptions.
Automated documentation with a CMDB
A Configuration Management Database (CMDB) is the central tool here. Unlike a static wiki, it records all configuration elements (CIs) and their relationships dynamically. Through automation and discovery tools that regularly scan the IT infrastructure, the data constantly remains up to date. This is the domain of specialised infrastructure management software.
Infrastructure management software supports IT teams in efficiently managing their complex environments. Modern tools offer far more than a simple inventory list.
Central functions
Good infrastructure management software typically includes:
Automated inventory: Agentless recording of all hardware and software components.
Visualisation: Graphical representation of network plans, dependencies, and rack occupancies.
Reporting: Comprehensive reports for licence management, security checks, and audits.
Change tracking: Traceable documentation of all changes to the IT infrastructure.
Lifecycle management: Monitoring of warranties, contracts, and end-of-life dates.
The use of specialised infrastructure management software brings measurable advantages: time savings, higher data quality, better bases for decision-making, and increased security.
Die Infrastrukturmanagement-Software unterstützt IT-Teams dabei, ihre komplexen Umgebungen effizient zu verwalten. Moderne Tools bieten weit mehr als eine simple Inventarliste.
i-doit INDITOR®,as infrastructure management software, offers a comprehensive solution for infrastructure management and IT documentation. The software supports you in the detailed recording of your entire IT infrastructure.
Complete documentation: i-doit INDITOR® automatically records all components of your IT infrastructure and sets them in relation to one another.
Location and room management: The software maps your physical infrastructure in detail – from buildings down to individual racks.
Cabling management: Document your network cabling in detail, including cable connections and occupied ports.
Making dependencies transparent: i-doit INDITOR® visualises dependencies between systems and applications so that you can identify the impacts of changes at a glance.
A well-thought-out, planned, cleanly documented, and continuously optimised IT infrastructure becomes a genuine strategic success factor. Companies that structure their infrastructure systematically, develop it purposefully, and document it completely benefit in multiple ways: they reduce downtimes, lower costs, and increase the security level of their entire IT landscape.
At the same time, companies thereby create the foundation to react flexibly to new requirements, technological developments, and growth at any time. Anyone relying on specialised infrastructure management software and reliable documentation invests sustainably: IT teams gain more room for maneuver and can focus more heavily on strategic projects and innovations.
