Cable management software for seamless cable mapping
Cable management software: How to document your cabling seamlessly
What is cable management software?
Cable management software and DCIM: What is the difference?
What errors occur without network cable management software?
What is part of a structured cable mapping process?
How does PATCH MANAGER by i-doit support cable management?
Cable management as a distinct discipline alongside data center operations
Imagine the following scenario: A technician stands in front of a server rack and has to find out which of the 48 cables leads to which device. If up-to-date documentation is missing, manual searching is often the only option: Every cable must be traced individually. Depending on the setup, this can take several hours.
What is already highly tedious for a single server rack becomes a major challenge as the infrastructure grows. In data centers, office buildings, and expansive outside networks, numerous cables, ports, and branches connect a multitude of devices. Without reliable documentation and appropriate software support, visibility over the cabling is quickly lost.
A precise overview is therefore essential: Which cable connects which port to which device? And how can cabling be reliably documented even when changes occur? This is where cable management software comes in. Learn what tasks it handles, how it differs from DCIM solutions, and how you can document your cable infrastructure efficiently and permanently.
Free live demo of PATCH MANAGER
The leading software for cabling and asset management. Discover PATCH MANAGER in a remote live demo.
Cable management software documents the physical cabling between ports, patch panels, and endpoint devices, making individual connections traceable at any time. The primary focus is the cable level. Aspects such as floor space utilization or power consumption are not part of its core scope.
Depending on the provider, such a solution is also referred to as a cable mapping tool or cable management software. Regardless of the term used, it revolves around the software-supported management of cables, connections, and routing pathways within the physical infrastructure. This includes cabling inside buildings (Inside Plant, ISP) as well as expansive outside infrastructures (Outside Plant, OSP).
Structured cable documentation aligns with established cabling standards such as ANSI/TIA-568 or ISO/IEC 11801. These define the categories for copper cables (from Cat 5e to Cat 8) as well as for various fiber types like OM3, OM4, and OS2. However, cable management software does not replace proper planning according to these standards. Rather, it helps record the deployed cable and connector types, connections, and run lengths in a consistent and traceable manner.
Anyone planning an expansion should therefore maintain documentation from the very beginning. Even in the planning phase, suitable structured cabling design software helps systematically define cable types, ports, and connection pathways. This allows planning errors to be identified early on, making subsequent expansions easier, faster, and more reliable to implement.
DCIM software maps the physical infrastructure of a data center holistically. This includes floor space, racks, power supply, cooling, and technical assets, among other things. Cable management software, on the other hand, focuses on the cable level and the associated connectivity. It does not matter whether the cables run within a data center, an office building, or an outside plant fiber optic network.
| Criterion | DCIM software | Cable management software |
| Focus | Floor space, racks, power, cooling, assets | Kabel, Patch-Panels, Ports, Fasern, Verbindungswege |
| Typical location | Data center | Data center, office building, OSP fiber network |
| Level of cabling detail | Cabling as part of the overall infrastructure | Detailed mapping of individual cables, fibers, connections, and routes |
| Typical question | Where are floor space, power, or cooling capacities available? | Which cable connects which ports or devices? |
| Primary benefit | Planning and management of physical data center infrastructure | Planning, documentation, and tracking of physical cabling |
In practice, there is overlap between both areas, as DCIM systems can also record cabling. The main difference lies in the level of detail of the mapping. Specialized cable management software can drill down to the individual fiber within a cable and, for example, document splice points and specific cable routes in detail. In DCIM software, however, cabling is usually just one of several aspects alongside racks and power supply.
DCIM and cable management should therefore be viewed less as competing solutions and more as systems with different focal points: While DCIM keeps an eye on the entire physical infrastructure, cable management enables highly detailed planning and documentation of the cabling.
Without structured cable management, numerous sources of error arise in day-to-day operations. If a centralized network cable management software is missing, changes are often documented decentrally by individual employees or merely passed on verbally. A uniform and traceable process is absent. This can lead to typical errors:
Missing or inconsistent labeling: If there is no standardized scheme for identifying cables, even repatching a connection becomes a risk.
Confusion of fibers: In fiber optic links with multiple fibers per cable, a lack of documentation at the fiber level can lead technicians to disconnect or splice the wrong fiber. Dedicated fiber cable management software reduces this risk through seamless documentation of every single fiber.
Undocumented cable pathways: If cable routes through trays and conduits are not sufficiently recorded, it is difficult to assess what capacities are still available before laying a new cable.
Double port assignment: Without a central database for cable mapping, different teams might schedule the same supposedly free port for different purposes.
Missing change history for patch panel connections: If a repatching is only communicated verbally, it is often impossible to trace later when a connection was changed and for what reason.
The lack of documentation becomes particularly critical at the handover points between indoor and outdoor networks. For example, if a fiber optic link runs from the building to a street cabinet and from there to another location, the complete connection path is very difficult to trace without end-to-end documentation.
A structured cable mapping process encompasses several consecutive steps that focus specifically on the physical cabling:
Record patch panels and ports: Every patch panel is documented with its port count, current assignment, and respective location. Patch panel cable management ensures that later repatching remains traceable.
Define cable type and standard: For each connection, the cable type used is documented based on the respective category or fiber type, for example, Cat 6A or OM4. The corresponding specifications come from the structured cabling design software used to originally plan the cabling.
Map connections end-to-end: Each cable segment is documented with its corresponding connection points. This allows the entire connection path to be traced across all involved patch panels and splice points.
Document cable routes: The physical path of the cables through trays, shafts, or conduits is recorded precisely. This makes it possible to identify available capacities and potential bottlenecks of individual cable pathways early on.
Standardize labeling: A uniform labeling scheme for cables and ports reduces the risk of mix-ups during manual work at the patch panel. Because even a comprehensive software solution is only helpful if technicians can clearly identify the documented cable on-site and locate it at the patch panel.
With PATCH MANAGER by i-doit, you document and manage cabling regardless of whether it runs through a data center, an office building, or an outside plant fiber optic network. As a network cable management software, PATCH MANAGER maps all network segments centrally in one system. In addition to connections, racks and systems can also be managed, ensuring that cables, racks, and devices are documented and maintained in one central location.
For connection tracking, PATCH MANAGER maps full end-to-end connectivity—regardless of the cable type used and the number of patch and splice points in between. In fiber optic networks, the software also enables documentation at the fiber level. Individual fibers within a cable can thereby be tracked separately and linked to splice points or spare fibers. This makes PATCH MANAGER suitable as fiber cable management software for the detailed documentation of complex fiber optic backbones.
Cable label management can also be centrally controlled with PATCH MANAGER. Manual and automatic labeling functions enable a standardized scheme across the entire cabling infrastructure. For OSP networks, the software additionally offers features for splice management and connection to inside plants. This allows, for example, a continuous fiber link from the street cabinet to the endpoint device in the building to be mapped in a single system.
Changes to patch panels and cable pathways can be documented via work orders. Moves, adds, and changes, including the required materials, can be planned before a technician physically changes a connection on-site. If i-doit is already in use for CMDB automation, the cable level can also be directly linked to the logical IT documentation. For example, switch ports can be connected to their respective physical patch cables and thus physically clearly assigned.
Cable management is far more than just a part of general data center documentation. It is an independent discipline with specific requirements and sources of error. If patch panels, fibers, cable connections, and cable pathways are clearly documented, errors can be found and resolved more quickly. This applies to data centers just as much as to office buildings and outside plant fiber optic networks.
Are you still relying on visual inspection and memory today to identify a cable on the patch panel? Then now is the right time to switch to a professional cable management software like PATCH MANAGER. This creates a reliable foundation for ongoing operations and ensures you are prepared for the next major expansion of your cabling infrastructure.
Book a live demo of i-doit now
Experience i-doit in action: In a personalized live demo, our experts show you how to effortlessly structure your IT documentation and CMDB. Over 2,000 customers already rely on our solution for their digital resilience.
