electric-industry-1200x800
i-doit Team20. October 2026
DCIM software for data center infrastructure management
9:14
1. DCIM software: How to systematically document and manage your data center
2. What is DCIM and what does the software do?
3. DCIM and IT asset management: What is the difference?
4. What risks arise without systematic DCIM?
5. Best practices for getting started with data center infrastructure management
6. PATCH MANAGER by i-doit: DCIM software for your data center
7. DCIM software as the foundation for a stable data center
A single incorrectly documented patch cable can already cause a massive disruption in a data center. Finding the root cause often requires substantial effort. With every additional rack, cable, and asset, keeping the physical infrastructure fully and accurately documented becomes even more difficult. If this information is also managed in Excel spreadsheets and Visio diagrams, visibility is quickly lost.
How can you prevent flawed cable documentation from leading to an unplanned outage? And how do IT teams maintain visibility as infrastructure, locations, and responsibilities grow? The answer lies in a centralized and structured solution. Learn what DCIM software delivers, how it differs from traditional IT asset management, and which best practices have proven successful in practice.
Free live demo of PATCH MANAGER
The leading software for cabling and asset management. Discover PATCH MANAGER in a remote live demo.
DCIM stands for Data Center Infrastructure Management and refers to the structured recording, visualization, and management of a data center's physical infrastructure. This includes, among other things, locations, rooms, racks, servers, network components, cabling, as well as power and cooling resources.
DCIM software maps these components digitally and makes their interdependencies visible. For example, it allows you to trace which device is connected to which switch via which patch cable. In contrast to pure monitoring software, data center infrastructure management software does not merely record the current operational status. It documents the entire physical infrastructure and also supports capacity planning as well as change tracking.
In this context, the term “Configuration Management Database” (CMDB) also frequently arises. A CMDB manages configuration items across the entire IT landscape—from servers and applications to contracts and services. DCIM software, on the other hand, focuses on the physical infrastructure of the data center, such as floor space, racks, cabling, and power supply. Both systems therefore serve different purposes, but can complement each other effectively.
Traditional IT asset management tracks devices, licenses, and contracts, supporting them throughout their entire lifecycle. Data center asset management goes a step further by also taking the physical infrastructure of the data center into account. This includes the exact position of devices in racks, their cabling, and the associated power supply.
 Approach Focus
 IT asset management Devices, licenses, and contracts, as well as their management throughout the entire lifecycle
Data center asset management Physical locations, racks, cabling, as well as power and cooling capacities
For data center operators, detailed documentation of the physical infrastructure is particularly critical. Data center asset management therefore supplements traditional IT asset management with information on cable routes, rack occupancy, and available capacities. This makes it possible to trace at any time which components exist, where they are located, and how they are interconnected.
Without structured documentation of the physical infrastructure, sources of error quickly emerge during ongoing operations. According to the Uptime Institute, nearly 40 percent of major data center outages over the past three years were attributable to human error. Insufficiently documented or outdated processes often play a role in this. Typical consequences include:
  • Faulty cabling: Without end-to-end documentation, it is often impossible to clearly trace which cable is connected to which device. If the wrong patch cable is disconnected, it can cause an unplanned outage.
  • Capacity bottlenecks: Without visibility into available rack space and power and cooling capacities, new hardware might be planned for the wrong location.
  • Lack of traceability during changes: If moves, adds, and changes are not consistently documented, the documentation drifts increasingly further from the actual state over time.
  • Prolonged troubleshooting: In the absence of reliable documentation, identifying and resolving the root cause during an incident takes significantly longer.
  • Compliance gaps: Without end-to-end documentation, meeting requirements and compiling audit evidence for ISO 27001 or BSI IT-Grundschutz requires substantial retrofitting effort.
In other words: The larger the infrastructure, the more severely gaps in physical documentation can impact operations.
Those who comprehensively record their physical infrastructure, map it digitally, and consistently document changes establish the foundation for secure and efficient operations. The following best practices highlight what matters most during implementation:
  • Fully capture the current state: First, inventory the existing infrastructure—including racks, devices, cables, and ports. Only a complete inventory creates a reliable foundation for further processes.
  • Build a digital twin: Map the physical infrastructure in a realistic digital model. This ensures that locations, capacities, and connections can be traced at any time.
  • Document end-to-end connectivity: Record every connection from the starting point to the endpoint device, regardless of cable type or run length.
  • Establish change management processes: Plan and document moves, adds, and changes using defined workflows before implementing changes in the data center.
  • Leverage reporting and capacity planning: Regular evaluations of rack utilization, power consumption, and available ports help you identify bottlenecks early and plan infrastructure proactively.
An IT emergency plan according to BSI Standard 200-4 also requires reliable documentation of the physical infrastructure. In an emergency, relevant components and connections must be quickly identifiable. Without this foundation, searching for information can cost valuable time.
As a data center infrastructure management software, PATCH MANAGER by i-doit models your data center as a digital twin. Racks, devices, and cable pathways can be documented using detailed, vendor-based device templates, ensuring that the digital documentation matches the actual physical layout.
Via integrated 2D and 3D visualization, you can navigate through locations, racks, and individual components. End-to-end connectivity management maps connections completely, regardless of the cable type used. This allows you to see at a glance how and through which path any device is connected to another.
Custom data fields are available for asset management. This allows you to document, for example, lifecycle statuses, IP addresses, or the power consumption of individual devices. With change management features, moves, adds, and changes can be planned and documented via work orders before being implemented in live operations.
PATCH MANAGER can also be utilized beyond the data center. If you also manage fiber optic networks outside of buildings, you can document splices and route pathways within the same system as part of outside plant fiber management.
In combination with the i-doit CMDB, the physical infrastructure can also be linked with logical IT documentation. Configuration items, contracts, and services from i-doit can be linked directly to the corresponding physical assets in PATCH MANAGER. This creates end-to-end documentation—from the logical IT structure down to the physical infrastructure.
Structured DCIM software replaces neither physical redundancy nor skilled personnel. However, it establishes the essential data foundation for reliable data center infrastructure management. Building on this, you can plan capacities, implement changes in a controlled manner, and prepare incident response processes.
Consistently documenting racks, cabling, and assets reduces the risk of human error during changes and enables faster troubleshooting during incidents. The first step is therefore a complete assessment of the current state. Building upon this, a digital twin is created that is updated with every change to the infrastructure.
See for yourself how PATCH MANAGER by i-doit supports you in the structured documentation and management of your data center infrastructure.
Book a live demo of i-doit now
Experience i-doit in action: In a personalized live demo, our experts show you how to effortlessly structure your IT documentation and CMDB. Over 2,000 customers already rely on our solution for their digital resilience.
