i-doit Team20. August 2026
Configuration management plan: ITIL, template, software
10:49
1. Configuration management plan: Definition, role of ITIL and template
2. Configuration management plan simply explained
3. What are the goals of a configuration management plan?
4. What are the benefits of a configuration management plan?
5. Configuration management and ITIL
6. How does ITIL support the configuration management plan?
7. Configuration management template
8. Components of a configuration management template
9. CMDB and configuration management software
10. Benefits of i-doit for configuration management according to plan
11. Configuration management plan as a success factor
According to the study "The State of Global Cyber Security 2025", German companies experience an average of over 1,200 cyberattacks per week. These are not just zero-day exploits. A large proportion of these attacks target known vulnerabilities in the IT infrastructure that could have been closed through consistent patch and configuration management.
Without structured processes and centralized documentation, such vulnerabilities persist and lead to system failures, security incidents, and economic damage. The configuration management plan closes this gap.
A configuration management plan (CMP) documents who is allowed to change what and when in your IT infrastructure, and how these changes are tracked. It enforces transparency, makes risks calculable, and forms the foundation for ITIL-compliant configuration management.
This article shows what makes an effective configuration management plan, how you can save time with a configuration management template, and what role the right software plays.
A configuration management plan (CMP) is a document that outlines processes, responsibilities, and guidelines for managing a company's IT landscape. It defines how Configuration Items (CIs) are identified, documented, and controlled throughout their entire lifecycle, including all general conditions. The plan answers the following operational questions:
  • Goals & scope: What should be achieved and which systems, locations, and services are affected?
  • Roles & responsibilities: Who bears which responsibility? How are the roles defined?
  • Processes & workflows: What do the specific workflows for the identification, control, and auditing of CIs look like?
  • Content & scope: Which information must be recorded for which CI? Which are optional?
  • Tools & technologies: Which tools are necessary for this technical implementation of the processes?
With a configuration management plan, companies have the technical and organizational foundation to cleanly document their IT landscape, pass audits, and keep the infrastructure stable.
Free trial phase of i-doit
Would you like to see the benefits of i-doit for yourself? Then try our software for free for 30 days.
A configuration management plan pursues four fundamental operational goals:
  • Establish transparency: All IT components and their dependencies should be centrally documented in the document as a "Single Source of Truth".
  • Increase efficiency: Change and release management should be standardized, accelerated, and safeguarded against sources of error.
  • Reduce risks: Potential impacts of technical changes should be identified before they cause disruptions.
  • Prove compliance: The configuration management plan should provide the basis to fulfill and prove regulatory requirements such as ISO 27001.
Behind all this is the meta-goal of making the organization's IT processes more efficient and secure. All sub-goals of the configuration management plan contribute to this.
The added value of a configuration management plan results from the increasing complexity of IT infrastructures. It is becoming increasingly difficult for administrators and IT managers to keep an overview. Changes without centralized control often end in configuration errors, unplanned downtimes, or open security vulnerabilities.
Specifically, the following benefits of a configuration management plan emerge:
  • Centralized management of CIs: All IT components are recorded in one place. Siloed solutions and outdated datasets are eliminated.
  • Transparency and control: Every change to the IT infrastructure is traceable and auditable.
  • Risk minimization: Dependencies are visualized, blind spots during changes are eliminated, and cascading errors are avoided.
  • Compliance and auditability: The configuration management plan creates the prerequisites to meet legal requirements and document everything seamlessly.
All details about the configuration management plan
Would you like to learn more about the procedure for creating a CMP? The free whitepaper offers a comprehensive overview.
In the ITIL framework (ITIL = Information Technology Infrastructure Library), configuration management holds an important position. It records, documents, and manages all Configuration Items and makes this information available across all processes.
According to ITIL, a CI is any element with relevance for IT services: servers, network components, software licenses, contracts, SLAs, or documentation. The goal of configuration management is a complete, up-to-date overview of the IT landscape. Not as an end in itself, but as a basis for informed decisions in change, incident, and problem management. A CMDB like i-doit keeps this information centralized and makes it available for all authorized processes and teams.
Within the framework, an ITIL-compliant configuration management plan relies on proven components that mutually reinforce each other in practice:
  • Standardization: ITIL defines concrete structures for CI management and change processes that are oriented towards real operational requirements.
  • Transparency: The CMDB acts as a Single Source of Truth for all Configuration Items along with their interdependencies.
  • Efficiency increase: Incident and problem management work on the same database. This eliminates media breaks and reduces coordination loops between teams.
An ITIL-compliant configuration management plan creates the foundation for reproducible IT processes according to internationally recognized standards and provides you with the control instruments you need for operating complex infrastructures.
A configuration management template provides the basic structure for a consistent configuration management plan, without you having to start from scratch for every project. It supports you in dealing with all relevant aspects of configuration management: from goal setting and process definitions to audit documentation.
A practical configuration management template covers the following areas:
  • Introduction and goals: Purpose definition of the configuration management plan with measurable KPIs.
  • Scope: Precise delimitation of the affected systems, locations, and services.
  • Roles and responsibilities: RACI matrix for all CM-relevant tasks.
  • Processes and workflows: Detailed process descriptions for identification, baseline management, change control, and configuration audits.
  • Tools and technologies: Binding definition of the deployed systems and interfaces.
  • Documentation and reporting: Defined reporting formats, update cycles, and escalation paths.
  • Continuous improvement: Fixed review intervals and adjustment mechanisms for the configuration management plan.
With a configuration management template, you accelerate the implementation and ensure that critical aspects are not overlooked.
Although the terms "CMDB" and "configuration management software" are often used synonymously, they refer to different things:
  • CMDB: The database in which all CIs and their relationships are stored. It is the passive foundation and the "Source of Truth".
  • Configuration management software: The active tool. It includes a CMDB but also offers additional features to execute, automate, and support the processes defined in the configuration management plan.
i-doit takes on the role of the Configuration Management Database (CMDB) and IT documentation platform with audit-proof data storage for the entire IT landscape. All Configuration Items are recorded and versioned, and their dependencies are modeled.
As the center of your configuration management software landscape, the platform connects processes, tools, and teams. Technical changes run faster as a result, risks become more calculable, and decision-making paths remain traceable.
In doing so, i-doit provides the database for all your ITIL processes: Change, incident, problem, and release management access impact analyses, seamless change histories, and auditable evidence. Every modification is logged. This simplifies internal reviews and external audits according to ISO 27001, BSI IT-Grundschutz, or industry-specific regulations.
Key features of i-doit for configuration management:
  • Structured CMDB documentation: Centralized recording of all CIs, from hardware assets and software licenses to contracts and services.
  • ITIL-compliant planning tools: Integrated features for creating and maintaining CM plans.
  • Dependency mapping for impact analyses: Graphical representation of CI dependencies shows which systems, services, and users are affected before any change.
  • Auditable logging: Seamless, immutable evidence of all configuration changes. Meets compliance requirements according to ISO 27001.
With i-doit as your central CMDB platform, you implement your configuration management according to ITIL standards and integrate it seamlessly into your existing tool landscape.
A configuration management plan is the prerequisite for controllable IT infrastructures. It makes dependencies visible, reduces change risks, and provides the evidence you need for audits and compliance checks.
What matters is not the document, but the actual practice. A CM plan only works if it is embedded in daily processes and continuously maintained. Tools like i-doit and well-thought-out configuration management templates accelerate the implementation and ensure that your configuration management runs according to ITIL standards.
Would you like to experience i-doit directly as a CMDB and learn more about configuration management according to ITIL? Then feel free to contact us.
