blog-generic-header-i-doit-it-engineer-checking-the-work-of-internet-cables
Pattrick Bluhm04. June 2021
Inventory with QR codes
3:56
What is a QR code?
The QR code is a two-dimensional code developed by the Japanese company Denso Wave in 1994. Originally, this format was used in the automotive industry. The automotive supplier Denso marked the components with these codes in order to optimise the logistics processes.
Due to an automatic error correction, this method is very robust and therefore widely used. Compared to the conventional barcode, much more information can be stored in a QR code. The field of application is expanded almost at will. Today, this code format can be found in all conceivable applications. Another advantage is the direct access to the information stored in the code. This is also where the name of the format comes from. “QR” stands for “Quick Response”.
What is a barcode?
A barcode consists of parallel bars and gaps of different widths. This is why it is often called barcode or strip code. The term “code” does not stand for encryption, but for the representation of data in binary symbols. The disadvantage compared to the QR code is proportionally a significantly lower content of information.
Barcodes usually contain sequences of numbers represented as stripes. Thus, the best-known application of barcodes is found in wholesale and retail. There, the article numbers or EANs (European Article Number) are applied as barcodes on the product packaging.
qr-codes-inventarisierung-01-barcode
How are barcodes / QR codes created in i-doit?
For each asset created, i-doit automatically creates a QR code. Depending on the settings in the administration area, the QR code automatically contains the selected information.
qr-codes-inventarisierung-02-objektFür A QR code is automatically generated for each object created in i-doit.
Configuration of the QR codes
QR codes can be used in different ways. Depending on the application, the generated QR code contains different information.
Variant 1: Calling up the object in i-doit.
When scanning the QR code, the object is opened directly in the browser. This allows changes to the asset to be made quickly or information to be made available.
Variant 2: Transfer of information
Instead of integrating a simple link to the asset, various information from the asset can also be used. This includes serial numbers, model, manufacturer, names/hostnames and IP addresses.
Label design
You have the option of additionally supplementing the printable labels with device information. Various placeholders are available for this purpose. Example: By using %sysid%, the SYS ID of the asset is automatically used on the label.
qr-codes-inventarisierung-03-gestaltungBy using the placeholders, additional information is printed on the label.
The placeholders can be inserted easily into the text template and customised.
qr-codes-inventarisierung-04-platzhalter
In addition to retrieving the information, it is also possible to design the labels with the QR printer tool. The spacing, alignment and size of the label are freely selectable. If desired, it is possible to include a logo. In addition, the position of the QR code is configurable. The use of a proxy server is also possible.
The connection to i-doit and the layout of the labels are configured in the settings of the QR Printer tool.
Acquisition of inventory data
The category “Accounting” can be activated for all object types in i-doit. In addition to the inventory number, all accounting information such as order number, delivery number and invoice number can be entered in this category. In addition, the cost centre used and the object’s cost can be entered. Warranty periods are calculated automatically from the available information.
QR-Code-Printer-Daten-laden
Reports for inventory
With i-doit Report Manager, you have an integrated tool that lets you capture all the information in individual reports. This allows you to filter all assets by any information, such as location, user, type, inventory number and much more.
qr-codes-inventarisierung-06-buchhaltung
qr-codes-inventarisierung-07-abfrageeditor
qr-codes-inventarisierung-08-report
Can barcodes also be used instead of QR codes?
To switch from QR codes to barcodes, you can find the corresponding settings under Administration > System settings > Client settings > QR code.
qr-codes-inventarisierung-09-experteneinstellungen
Alternatively, the following entries can also be added under System settings -> Expert settings.
pattrick-bluhm
Pattrick BluhmExperten
