i-doit Team15. September 2026
ITIL Service Management: A Guide to ITSM According to ITIL
10:08
1. ITIL service management: How to successfully implement ITSM according to ITIL in practice
2. What is ITIL service management?
3. The difference between ITIL service management and ITSM
4. The five phases of the ITIL service lifecycle at a glance
5. From the ITIL service lifecycle to the ITIL 4 Service Value System
6. The most important practices for ITIL service management
7. The importance of ITIL service management for IT teams
8. Transparency across the service lifecycle through ITIL service management with i-doit
9. ITIL service management as the foundation for excellent IT services
The demands on IT departments are high: Services need to be delivered quickly, run reliably, and remain cost-effective at the same time. In practice, however, teams often face challenges such as unclear processes, inefficient workflows, and a lack of transparency.
According to a study by the Service Desk Institute, 71% of surveyed organizations are already exploring the use of AI solutions in ITSM. This underscores the pressure placed on IT. This is precisely where ITIL service management comes in: It provides a proven framework for planning, operating, and continuously improving IT services in a structured manner.
With ITIL, you gain not only a collection of proven best practices, but also a clear guide for implementation within your organization. Discover what ITIL service management means for your IT, how the ITIL service lifecycle is structured, and how to successfully establish ITSM according to ITIL.
Free Trial version of i-doit
Would you like to experience the benefits of i-doit for yourself? Try our software free for 30 days.
ITIL service management refers to the application of ITIL best practices to control and optimize IT services. The IT Infrastructure Library (ITIL), originally developed in the United Kingdom in the 1980s, has established itself as the international de facto standard for IT service management (ITSM).
The core goal of ITIL service management is to view IT services not as isolated technical units, but as value-adding services that directly contribute to the company's business goals. ITSM according to ITIL encompasses the entire lifecycle of IT services, from requirements analysis and incident management to strategic development.
Although the terms ITSM and ITIL are often used synonymously, they describe different levels:
  • ITSM is the discipline: The overarching concept for holistic management of IT services. It describes what needs to be done.
  • ITIL is the framework: The process-oriented guidance for implementing ITSM. It shows how implementation can be achieved.
In short: ITSM is the goal, ITIL is the path to get there. The combination of ITSM according to ITIL and the right software tool support forms the foundation for professional IT service management according to ITIL.
Until the introduction of ITIL 4 in 2019, the ITIL service lifecycle formed the core principle for structuring IT services. It was divided into five consecutive phases:
  • Service Strategy: Defines which services are offered and how they support business success.
  • Service Design: Develops new services or revises existing ones while taking technical, organizational, and economic requirements into account.
  • Service Transition: Ensures that new or changed services transition into live operation in a controlled manner and with minimal risk.
  • Service Operation: Ensures the reliable operation of services and guarantees compliance with agreed SLAs.
  • Continual Service Improvement: Identifies improvement opportunities, measures service quality, and continuously develops processes.
From the ITIL service lifecycle to the Service Value System of ITIL 4
ITIL 4 evolved the classic lifecycle model into the Service Value System (SVS). A flexible operating model that adapts to different ways of working replaces a rigid, sequential sequence.
The core elements of the Service Value System are:
  • Guiding Principles: Seven core principles serving as the foundation for decisions.
  • Service Value Chain: Six central activities (Plan, Improve, Engage, Design & Transition, Obtain/Build, Deliver & Support).
  • Practices: 34 management practices, divided into general, service, and technical management.
The advantage of ITIL 4 lies in its compatibility with agile methodologies. It can be seamlessly combined with approaches such as Agile, DevOps, or Lean IT. This allows organizations to implement IT service management in practice with ITIL without having to abandon existing agile structures.
Of the 34 practices in ITIL 4, the following are particularly relevant for daily IT service management according to ITIL:
  • Incident Management: Fast response to disruptions to restore normal operations.
  • Problem Management: Analysis of the underlying root causes of recurring incidents.
  • Change Management: Controlled planning and execution of changes to the IT infrastructure.
  • Service Level Management: Definition, agreement, and monitoring of service levels.
  • Configuration Management: Management of all Configuration Items (CIs) in a Configuration Management Database (CMDB).
The implementation of ITSM according to ITIL leads to measurable benefits:
  • Higher service quality: Structured processes reduce errors and shorten response times.
  • More efficient resource utilization: Clear responsibilities minimize duplicate work and lower operating costs.
  • Complete transparency: Real-time insights into which services are being delivered at what quality.
  • Improved user satisfaction: Faster and lasting problem resolutions strengthen trust in IT
Transparenz über den Service-Lifecycle durch ITIL-Servicemanagement mit i-doit
 Successful implementation of ITSM according to ITIL requires a reliable data foundation. i-doit supports you through centralized IT documentation that consolidates all relevant information as a single source of truth.
Mapping the ITIL service lifecycle in i-doit
With i-doit, you document and control services across the entire ITIL service lifecycle:
  • Service Strategy: Record service portfolios and map dependencies to business processes.
  • Service Design: Model service architectures and their dependencies on underlying infrastructure.
  • Service Transition: Manage changes to CIs with seamless versioning.
  • Service Operation: Link services directly to physical and virtual infrastructure components.
  • Continual Improvement: Utilize detailed reports for data-driven optimization decisions.
Mapping the ITIL service lifecycle in i-doit creates the data transparency that is essential for professional IT service management in practice with ITIL.
Integration with service desk systems for ITSM according to ITIL
i-doit integrates seamlessly with leading service desk solutions:
  • Zammad: Automatic synchronization of assets and tickets
  • OTRS/Znuny: Bidirectional integration for incident and request management
  • Jira: Linking tickets to CMDB objects
An example of IT service management in practice with ITIL: A user reports an outage on a server. The ticket automatically displays all relevant information from the CMDB, such as hardware configuration, installed software, or dependencies on other services. The technician immediately sees the resolution path. The disruption is resolved in minutes instead of hours.
Transparency across services and their dependencies in ITIL service management
i-doit visualizes complex service structures and makes dependencies visible:
  • Service trees: Hierarchical representation of services and their subordinate components.
  • Impact analysis: Simulation of the impact on higher-level services if a component fails.
  • Relationship mapping: Graphical representation of all dependencies between CIs.
This transparency forms the basis for effective incident and problem management according to ITIL.
Support for IT service management in practice with ITIL
Implementing IT service management according to ITIL succeeds with a structured approach:
  1. Inventory: Analyze your IT landscape and build a meaningful CMDB.
  2. Prioritization: Start with the practices that promise the greatest value, such as incident, change, and configuration management.
  3. Quick wins: Achieve quick wins to make the benefits of ITIL service management visible across the company.
  4. Team involvement: Ensure the necessary buy-in through training and open communication.
  5. Continuous measurement: Define KPIs such as Mean Time to Repair (MTTR) or First Call Resolution Rate to track progress.
The key to success lies in establishing ITSM according to ITIL not as a one-off project, but as a continuous improvement process.
Achieving excellent IT services with ITIL service management
ITIL service management is far more than a process framework. It serves as a strategic approach to align IT systematically with business value. The ITIL service lifecycle provides a proven guide for this—from service planning and delivery to continuous improvement.
With i-doit as a CMDB, you establish the necessary data foundation to implement IT service management according to ITIL. The solution comprehensively documents services and infrastructure, seamlessly connects with common service desk systems, and creates the transparency required for ITIL-compliant workflows. i-doit thus provides the right tool to efficiently realize ITSM according to ITIL and professionally manage the entire ITIL service lifecycle.
Would you like to anchor ITIL in your organization or further develop existing ITSM processes? i-doit provides exactly the support you need.
