Topology in IT: Network Topology and its Types
1. Topology in IT: Network topology and its types at a glance
2. What is topology in IT?
3. Types of network topologies
4. Topology in IT documentation and in CMDBs
5. Clearly structured network topology: Advantages at a glance
6. Success factor in IT: A clear network topology
What does the term "topology" refer to? In short: it indicates how the individual components of a system are arranged and how they communicate with each other. The term originally comes from mathematics but is now used in other specialist fields as well. These include geography, biology or indeed information technology. This can involve both physical connections and abstract, logical relationships.
Topology brings structure to complex IT environments. It shows at a glance how components are connected, which dependencies exist and where potential vulnerabilities lie. But which types of topology are there? And what significance do they have for operations and network documentation? In this article, we show you which topologies are relevant in the AI context and how they can be effectively mapped using a Configuration Management Database (CMDB).
In IT, a topology describes the type of networking between devices or systems. A fundamental distinction is made between two levels:
- Physical topology: This describes the actual arrangement of the hardware, i.e. the physical connection of devices, for example via cables, hubs, switches and routers. In this way, the physical topology represents how the components are arranged in the room and physically connected to each other.
- Logical topology: This represents how data flows through the network – regardless of the actual arrangement. For example, a star topology can exist physically, while the logical communication follows a ring topology.
A classic example: in a network, all devices are connected to each other in a star shape via a central switch. Nevertheless, the logical topology can be designed such that the data passes through several nodes one after the other, similar to the Token Ring protocol.
Step-by-Step to Documentation Success
Where to start? What exactly should we document? Many IT projects search for orientation in the beginning. With our whitepaper "In 6 Steps to IT Documentation," you receive a red thread that brings you focused to your goal.
CTA: Download Whitepaper Now!
IT systems can be structured using various topologies – each with specific advantages and typical use cases. Which topology fits your network depends on factors such as scalability, security, performance, maintainability and reliability. Here we present common topologies to help you find the right solution:
Star topology
In a star topology, all end devices are connected to a central hub or switch – a simple and physical connection. Currently, this is the most widespread type of network topology. It is used particularly in Ethernet-based networks.
Advantages:
Good fault diagnosis: the failure of one device does not directly affect the entire network
High flexibility for expansions
Fast access to the transmission medium
Disadvantages:
The central node is a Single Point of Failure (SPOF) – if the hub or switch fails, the entire network is affected
Higher cabling effort compared to bus or ring topologies
Bus topology
In a bus topology, all devices are connected to each other via a single cable. This serves as a common transmission medium. This simple structure was particularly widespread in the past.
Advantages:
Low cabling effort
Simple setup
Disadvantages
A defective cable or poor termination can cause the entire network to fail
Common access method leads to potential collisions
Limited scalability
Ring topology
In a ring topology, all devices are connected to each other in a circle: data packets are forwarded from node to node in a fixed direction. Thus, every device is part of the transmission path and actively forwards the data.
Advantages:
Even load distribution
Efficient use of bandwidth
Disadvantages:
The failure of a device or a connection interrupts the entire data flow
Difficult troubleshooting compared to the star topology
Mesh topology
The mesh topology (fully or partially meshed) connects every device to one or more other devices. This type of networking is primarily used in high-availability environments.
Advantages:
Highest reliability/fail-safety
Redundancy and optimal data paths
Disadvantages:
Very high cabling effort
High complexity in configuration
Tree topology
In this type of topology, features of the star and bus topologies are combined. This results in a hierarchical structure consisting of several interconnected nodes. The tree topology is particularly suitable for large networks: clear structuring and easy expandability are possible.
Advantages:
Good scalability
Logical grouping of networks
Failure of individual end devices does not affect the overall network
Disadvantages:
The failure of a central distributor can paralyse large areas of the network
Higher administrative complexity
Point-to-point topology
The point-to-point topology connects exactly two devices directly to each other – without detours or intermediate devices. This creates a fast, stable and secure connection. It is well-suited for simple, clearly defined connections, for example between two servers or locations.
Advantages:
High data transfer rate
Maximum security
Disadvantages:
Hardly scalable
Not suitable for larger networks
For modern IT organisations, precise documentation is indispensable. It forms the basis for an understanding of the infrastructure, facilitates fault analysis and supports well-founded decisions during expansions.
With i-doit as a Configuration Management Database (CMDB), you capture not only individual IT assets such as servers, routers or access points, but also their relationships with each other. This creates a complete image of your network topology – from the cabling in the data centre to virtual connections in the cloud.
This leads to complete transparency over your IT infrastructure. All devices, connections and dependencies are documented in a central location – consistently. In this way, the topology can be visualised and analysed in real-time, for example during changes, disruptions or expansions.
Created networks are fully represented in IPAM (IP Address Management) with all valid addresses. In this way, management and IT administrators always have a complete overview of corporate networks.
This results in further advantages: new employees can be onboarded more quickly and independent familiarisation is also possible. Furthermore, IP networks and virtual networks (VLANs) can be documented.
With a clearly documented network topology, you create the basis for smooth operations, efficient maintenance and a future-proof development of your IT infrastructures:
Efficiency: A clearly structured topology simplifies the commissioning and maintenance of your network. Connections between devices are immediately apparent – this accelerates troubleshooting and shortens reaction times in the event of disruptions.
Scalability: A well-thought-out topology makes it easier for you to add new devices or segments. Whether additional workstations, new departments or entire locations: expansions can be carried out specifically and without major restructuring.
Security: This advantage focuses on the transparency of the network structure. You can see at a glance how systems are connected to each other and can identify potential vulnerabilities early on. In this way, you secure attack surfaces specifically. Additionally, the integration of new systems can be precisely planned based on a good database. This prevents conflicts in the network or misconfigurations.
Cost reduction: With a traceable topology, you minimise configuration errors, save yourself duplicate work and reduce the effort for IT administration. This saves you time and noticeably reduces your operating costs – especially in large and dynamic IT environments.
Transparency: The structured presentation makes the network easier to understand. This applies not only to administrators but also to other stakeholders. This promotes collaboration between IT and other departments and creates a reliable basis for planning and decision-making.
The performance, security and maintainability of your IT systems depend heavily on the network topology. In order to be able to manage complex structures clearly and efficiently, you need the right tools. With the i-doit CMDB, you document physical and logical network connections in an efficient manner.
From simple point-to-point connections to complex tree or mesh topologies: i-doit enables a comprehensive representation of your network components including dependencies. Thanks to integrated interfaces to discovery tools like JDisc or monitoring systems, much of the information can be captured automatically and kept constantly up to date.
This not only massively increases data quality but also reduces manual maintenance effort to an absolute minimum.
Would you like to document your network topology reliably and make your IT infrastructure transparent and future-proof? Let us show you how i-doit can support you.
