professional-it-specialist-1200x800
i-doit Team07. May 2026
Using IPAM – managing and documenting IP addresses
11:08
1. IPAM: efficiently managing and documenting IP addresses
2. What is IPAM?
3. Core elements of IPAM systems
4. Why is IPAM important?
5. Using i-doit and IPAM: functions and added value
6. Comparison of popular IPAM solutions
7. Need for action during the transition from IPv4 to IPv6
8. Integration with DNS and DHCP: why DDI is important
9. Best practices for your IPAM strategy
10. Conclusion: IPAM enables stable IT operation
The management of IP addresses is now a central building block of every secure and stable IT infrastructure. However, whether in healthcare or many other sectors, IP Address Management (IPAM) is increasingly presenting IT teams with challenges. The global shortage of IPv4 addresses and the transition to IPv6 are increasing the pressure on IT departments to set up their networks for the future.
Without a central tool for IPAM, IT teams quickly reach their limits. Manual management becomes error-prone, confusing, and time-consuming. It primarily comes down to the following questions: Which devices have which IP? Where is there still free capacity in the IPv4 network? Where is a device located on the network that shouldn't actually be there?
An IT documentation solution like i-doit offers effective support here: with integrated IPAM functions, you document and monitor networks centrally, utilise existing resources, identify planning errors, and maintain an overview even as networks grow. This saves valuable time.
In this article, you will learn what IPAM actually is, what benefits it offers, and how to professionally implement IPAM with the i-doit CMDB.
What is IPAM?
IPAM stands for "IP Address Management" and describes the systematic management of all available and used IP addresses within a network. This is not just about storing IP address ranges: IPAM includes the planning, documentation, and analysis of the entire network infrastructure. Modern IPAM solutions combine functions from IT documentation, automation, and reporting. In this way, they make the management of your IP addresses central and efficient—and help to resolve problems quickly.
IPAM contributes significantly to network security: it monitors the use of IP addresses, detects unauthorised devices, and supports compliance with regulatory requirements. For companies with high regulatory demands, such as data centres, critical infrastructure (KRITIS) operators, hospitals, and public administrations, a central IPAM system is indispensable.
A high-performance IPAM system offers various functions that simplify the management or assignment of IP addresses. All relevant information—e.g. IP addresses and hostnames—is presented in a dashboard and is easily accessible thanks to a clear user interface.
Central components include:
  • Central IP address database: All assigned and available IP addresses are systematically recorded and managed.
  • Subnet and VLAN management: The network structure is logically organised, which increases clarity and scalability.
  • Integration with DNS/DHCP: By connecting with DNS and DHCP servers, name resolution and address assignment can be automated.
  • Monitoring and reporting: The current state of the IP infrastructure can be analysed and presented in reports at any time.
The use of IPAM software to manage IP addresses is more than just a technical or organisational measure: it increases the operational security and efficiency of your IT.
The advantages of IPAM solutions at a glance:
  • Transparency and control: Maintain an overview of IP assignments, free address ranges, and used networks at all times.
  • Avoidance of IP conflicts: Duplicate IP addresses lead to disruptions. An IPAM tool detects and prevents such problems early.
  • Efficient resource utilisation: Free IP addresses become visible and can be purposefully assigned—particularly important with scarce IPv4 resources.
  • Automation and integration: By connecting to existing systems such as IPAM servers or network management tools, you reduce manual tasks.
With i-doit, you record and manage your networks comprehensively and reliably. Compared to the manual management of IP addresses, the software offers flexible options for expansion through additional categories, text fields, and data. This allows for adaptation to the individual requirements of your IT department through the following functions:
  • Management of IP addresses: Manage and document every single IP address—with history, status, and links to devices or services.
  • Automatic updates: Devices with a registered IP address are automatically added to the IPAM, completely eliminating duplicate data maintenance.
  • Subnet management: Structure your network logically and document subnets along with associated IP ranges.
  • Integration with DHCP and DNS: Rely on automated DHCP and IPAM processes to ensure consistent, transparent, and error-free assignment.
  • Visualisation: Networks can be represented visually, which simplifies analysis and troubleshooting.
  • Reporting: Create customisable reports on IP utilisation, free addresses, and potential conflicts at the touch of a button.
 Further information on the IPAM functions of i-doit can be found in thei-doit Knowledge Base.
The i-doit CMDB provides integrated IPAM that goes beyond simple lists. You do not just manage IP addresses; you create a networked view of your entire IT infrastructure.
7 myths of CMDB projects: fact check
In our guide, which is around 25 pages long, you will receive valuable tips on how to build a functioning CMDB in your company. Clear, practical, and informative.
 To better categorise i-doit as IPAM software, it is worth looking at other common solutions on the market:
IPAM Tool  Special Features
Infoblox IPAM Integrated DDI solution with high scalability.
SolarWinds IPAM Provides a user-friendly interface and comprehensive functions.
phpIPAM Open-source, suitable for smaller networks.
BlueCat IPAM Focus on automation and security.
 These tools differ in depth of function, integration options, and pricing. While standalone use is possible, i-doit scores particularly well through the seamless integration of IPAM into the IT documentation and CMDB, as well as its user-friendly licensing model.
The shortage of IPv4 addresses is a genuine problem for cybersecurity. This is why Network Address Translation (NAT) is employed. Although this allows multiple devices to use a single IP address, it complicates the identification of individual devices. This makes network monitoring quite complex, and it becomes difficult to detect attacks or unusual activities.
Furthermore, IPv4 addresses can certainly be tainted—for example, by spam or previous fraud attempts. This impairs trust in your organisation and its digital integrity. Additionally, the risk of IP address hijacking increases: cybercriminals seize unused or poorly secured IP blocks to misuse them for attacks such as DDoS or phishing.
In short: the introduction of IPv6 is the right step in the long term. IPv6 provides virtually unlimited addresses and integrates important security functions. However, the complete transition is often complex and time-consuming. Therefore, two accompanying measures are recommended:
  1. The careful selection during IP leasing to avoid tainted addresses.
  2. The securing of the Border Gateway Protocol (BGP) with technologies such as RPKI.
One thing is certain: professional IP address management forms the basis for the successful implementation of these measures. It creates transparency, increases security, and ensures greater efficiency in the management of IP resources.
A modern IPAM system should not operate in isolation. It is only through integration with DNS (Domain Name System) and DHCP (Dynamic Host Configuration Protocol) that a high-performance overall system is created. This combination is referred to as DDI and forms the basis for automated, holistic, and secure network management.
DDI solutions enable central control, minimise misconfigurations, and support the smooth migration to IPv6. They thus make an important contribution to digital transformation and ensure the future viability of modern IT infrastructures.
Advantages of a DDI solution:
  • Automated processes: DDI enables automated IP assignment and hostname allocation.
  • Centralisation: All network-relevant data is bundled into a single system.
  • Error minimisation: Through consistent data sources, the risk of configuration errors is reduced.
To ensure your IPAM strategy works in the long term, you should rely on proven methods. The following best practices will help you to optimise your IP infrastructure:
  • Establish central management: Use a central IPAM tool to ensure consistency and traceability.
  • Clear naming conventions: Uniform naming simplifies assignment and reduces sources of error.
  • Regular audits: Check your IP data regularly and clean up outdated or unused addresses.
  • Promote system integration: Connect DNS, DHCP, and other systems – a modern IPAM server should be seamlessly integrated.
  • Documentation & training: Record processes in writing and train your team in using the IPAM software.
Conclusion: IPAM enables stable IT operations
Professional IP address management is the foundation for stable IT operations. Whether you want to avoid IP conflicts, make optimal use of resources, or automate network processes – a high-performance IPAM tool provides you with the necessary tools.
With i-doit, you manage IP addresses in a particularly structured and central manner: the integrated IPAM module provides you with a complete overview of all relevant network information. You can see at any time which IP addresses are occupied or free, prevent collisions, and increase the planning security of your infrastructure. Thanks to automated functions – such as determining the next free IP address or simple subnet segmentation – you simplify management even further.
The additional advantages at a glance:
  • Definition of network ranges for the clear classification of IP devices.
  • Representation of dynamic and reserved DHCP ranges.
  • Mapping of Layer 2 networks, including associated devices.
  • Summarisation of Layer 3 networks into so-called supernets.
Through integration into the CMDB, you obtain a comprehensive overview of your entire IT infrastructure. Would you like to learn more? Find out now about the IPAM functions of i-doit in connection with the CMDB – or contact our support team directly for a personal consultation.
We can help you find the right solution for your requirements! Alternatively, you can test i-doit without obligation for 30 days with all functions.
Document IP addresses and networks professionally now.
The i-doit group offers the leading solution for central IP address management (IPAM) and integrated IT documentation. Avoid IP conflicts, manage IPv4/IPv6 networks efficiently, and strengthen your digital resilience through a seamless data basis.
