Avoiding IT downtime: identifying causes, minimising risks
1. Safely avoiding IT downtime
2. Causes of IT downtime
3. IT outages and their impact
4. Strategies for avoiding IT downtime
5. Monitoring for comprehensive IT security
6. Developing and regularly testing IT emergency plans
7. Solutions for greater IT security
8. Conclusion: well-prepared for an IT emergency
An IT outage affects every type of organisation significantly: when business-critical processes are disrupted, it inevitably leads to a loss of revenue. In the medical sector, it can even lead to life-threatening situations. Dangerous situations can also quickly arise in aviation—a well-known example being the CrowdStrike incident in July 2024.
IT downtime is caused by various factors: these include hardware defects, software errors, and human error. It becomes particularly critical when central systems are affected that you rely on in your daily work. The good news: with clearly defined processes, suitable tools, and targeted prevention measures, you can significantly increase the resilience of your IT.
In this article, you will learn the typical causes of IT downtime and how to keep your IT stable and reliable through structured IT documentation, effective monitoring, and automated workflows.
IT outages often have serious consequences for companies: they can lead to productivity losses, high financial damage, and, in the worst-case scenario, a loss of reputation. However, much can be done with professional IT Service Management (ITSM) to minimise these risks.
The most common causes of IT system failure are:
- Hardware defects and ageing: Servers, hard drives, or network devices often fail suddenly—particularly with ageing infrastructure. Such a failure of IT components can trigger domino effects throughout the entire IT environment.
- Software errors and incompatibilities: Untested updates or incorrectly configured systems quickly lead to IT downtime. External dependencies—as observed during the CrowdStrike outage—also have far-reaching consequences.
- Human error: Faulty operation, insufficient training, or uncoordinated changes to the system by both internal staff and external service providers are among the most common causes of IT outages.
- Cyberattacks and security vulnerabilities: A targeted attack on your IT, such as through ransomware or targeted network sabotage, quickly leads to the failure of IT systems.
- Lack of redundancies and insufficient emergency planning: Many companies do not have a complete IT emergency plan or do not test it regularly. In an emergency, clear responsibilities, process plans, and communication channels are then missing.
With a solid emergency plan, structured IT documentation, and automated processes, many outages can be avoided and their impact significantly limited.
IT disruptions can bring companies to a complete standstill within seconds. The global IT outage of 2024 demonstrated impressively: as soon as central business processes are affected, things quickly become critical—regardless of whether the trigger was a cyberattack, a technical defect, or human error.
System failure in IT is now one of the greatest risks in the digital age. Following an IT glitch or a cyberattack, many companies must first cease operations as they cannot access computer systems. This applies to international airports and small-to-medium-sized enterprises (SMEs) alike.
Structured and up-to-date IT documentation is the basis for fast and targeted action in the event of a disruption. With a Configuration Management Database (CMDB) like i-doit, IT teams gain a complete overview of the IT infrastructure, including all assets, dependencies, and statuses. In addition to stronger cybersecurity, you benefit from faster fault diagnosis and reduced impact.
Advantages of a CMDB:
- Central and audit-proof information consolidated in one place.
- Fast fault diagnosis through clear dependency visualisations.
- Minimisation of human error through documented processes.
- Reduced training effort through a standardised information base.
Manual recording of IT assets is prone to errors and often remains incomplete. With the IT Discovery function of i-doit, you scan the entire network and record all hardware and software components. This allows you to ensure seamless IT asset discovery.
Benefits and utility of an IT documentation solution:
- Continuously updated data basis.
- Early detection of potential vulnerabilities.
- Reduction of response time in the event of a disruption.
- Capability for IT emergency planning through emergency manuals, restart plans, and disaster recovery concepts.
Temperature increases in servers, storage bottlenecks, or network latencies: a reliable monitoring system detects such anomalies early. This allows IT managers to be certain they have everything in view, as changes in the IT landscape are a frequent source of disruption.
A combination of monitoring and documentation enables a faster response. Professional Change Management for the IT infrastructure also helps to make changes transparent and implement them in a controlled manner. This avoids conflicts, outages, and complicated rollbacks. Furthermore, a detailed target/actual comparison is possible.
Regular updates for firewalls and anti-malware, as well as a comprehensive permissions concept, are always mandatory. In addition, emergency plans and backup strategies should be documented and regularly tested.
An IT emergency plan is mandatory—not just for large corporations. It regulates responsibilities, contact chains, recovery procedures, and communication channels. The Federal Office for Information Security (BSI) provides templates for emergency plans. However, it is important that this plan is regularly tested and adapted to your own infrastructure and processes so that IT systems remain stable even during a global IT outage.
Components of a good emergency plan:
- Technical restart plans.
- Contact lists for internal and external escalation.
- Backup and recovery strategy.
- Communication guidelines for stakeholders.
Your advantage: With i-doit, you can automatically create an emergency manual or plan that works for your company. As a central platform for IT documentation, the software is a useful tool in this case and simple to use.
To ensure you can act quickly in an emergency and minimise the impact of IT outages, i-doit provides various solutions:
Outage simulation and impact analysis with the Analysis Add-on
With the Analysis Add-on, you simulate the failure of individual components or entire services within the CMDB. This allows IT teams to identify potential impacts of an outage early and initiate appropriate risk-minimisation measures. In other words: the function supports you in the development and testing of emergency plans for IT outages.
ISMS and VIVA2 Add-ons for information security and risk management
TheISMS and VIVA2 Add-ons support you in implementing an Information Security Management System (ISMS) according to ISO 27001 and BSI IT-Grundschutz. They offer central functions for risk analysis, audits, and the documentation of security measures—making an important contribution to avoiding IT outages caused by security gaps.
By integrating the Checkmk 2 Add-on, organisations additionally gain powerful monitoring for their IT systems. This allows anomalies and potential outages to be detected early. Hosts can be transferred from the IT documentation to the monitoring system or synchronised from there back into the documentation, ensuring a central data basis.
Efficient maintenance planning with the Maintenance Add-on
The Maintenance Add-on supports you in the planning, documentation, and monitoring of regular maintenance work. This ensures your systems remain up to date and reduces the risk of failure due to outdated or unmaintained components.
Target/actual comparisons for stable IT configurations
With the ITIL Baselines in i-doit, you can compare the target and actual states of your IT infrastructure at any time. This allows you to identify deviations early and rectify them before they lead to outages.
IT outages can never be completely ruled out. However, with the right security software, effective prevention, and stable systems, you can significantly reduce both the probability of occurrence and the consequences.
With structured IT documentation, automated workflows, and a proven emergency plan, you lay the foundation. The practical solutions from i-doit support you in preventing outages early and ensuring you remain capable of acting in an emergency.
We can help you find the right solution for your requirements! Feel free to contact one of our experts. Alternatively, you can test i-doit for 30 days with all functions, without obligation.
