i-doit 36 released: New JDisc Connector add-on, i-doit add-on Flows 1.2, and more
Key highlights of i-doit 36
We are pleased to announce the release of i-doit 36, which brings significant updates and improvements to make your IT documentation and automation more efficient. This release introduces significant changes to the JDisc interface, a feature-rich update to the i-doit add-on Flows and full compatibility with PHP 8.4 for i-doit and all add-ons. A detailed list of all changes can be found in the official changelog.
With i-doit 36, the JDisc Connector add-on replaces the JDisc functionality previously integrated into the core product. This modular approach allows us to introduce new features and further improve the user experience in the future.
What does this mean for existing users?
Update from i-doit 35: Your JDisc interface will remain until you install the new add-on, which will completely replace the old interface and migrate your data. Please note: This migration cannot be undone. You can continue to use the old interface for the next two i-doit versions before the change becomes mandatory.
Reinstallation of i-doit 36 (or higher): You must install the JDisc add-on in order to use the functions of the JDisc interface.
The first feature developed for the new add-on is the device list, which gives you quick access to your devices and simplifies the import of new devices via a single interface.
i-doit Add-on Flows version 1.2
The i-doit add-on Flows receives its first major feature update with version 1.2:
Classification of objects between the states "Normal", "Archived" and "Deleted".
Improved trigger buttons: Now with icons for quick identification, grouping function for triggering multiple flows simultaneously and category-based visibility.
Enhanced logical conditions: Creating conditions for flows is now even more intuitive and user-friendly.
These updates make the i-doit Flows add-on an even more powerful tool for automating IT workflows and reducing manual effort.
Add-ons QR Code Printer & i-diary
The QR Code Printer and i-diary add-ons, which are available as Windows applications, can now be installed directly in i-doit. After installation, users have access to:
An introduction and instructions for the add-on
Download links for the corresponding Windows applications
A direct connection to your i-doit server for seamless operation
This makes integrating these tools easier than ever.
Further highlights in i-doit 36
The JDisc interface is now fully modular and available as an add-on.
Numerous new features and UX improvements for the i-doit add-on Flows.
i-doit Cloud users can now configure additional expert settings themselves.
The use of self-signed certificates for LDAP is now possible via the interface.
Microsoft Windows-based add-ons can now be installed directly.
Add-ons compatible with i-doit 36
The following add-on versions are available parallel to i-doit 36:
JDisc Connector 1.0
i-doit Add-on Flows 1.2
API 2.4
Documents 1.11
Floorplan 1.10
Maintenance 1.7
Workflow 1.6
Packager 1.4
Make sure you update your add-ons accordingly to meet the requirements of i-doit 36.
Upgrade to i-doit 36 today to benefit from the new features, enhanced add-ons and improved performance!
👉 If you have any questions, please contact our support team.
Your solution for ISMS, data protection & GRC
Test the i-doit GRC Suite free for 30 days – in the cloud or on-premises.
More than 400 companies successfully manage information security, risks, and compliance with i-doit.
