female-it-engineer-in-data-center-1200x800 (1)
i-doit Team04. August 2026
ITIL processes & ITIL implementation: the practical guide
9:21
1. ITIL processes simply explained: overview and implementation
2. Definition: what are ITIL processes?
3. ITIL process overview: practices for stable IT operations
4. The shift from ITIL V3 to ITIL 4 – ITIL processes simply explained
5. A pragmatic approach to ITIL implementation in practice
6. Implementing ITIL process management in a practical way
7. CMDB integration is the technical foundation of ITIL implementation
8. ITIL processes with i-doit as a CMDB
9. Using ITIL processes as a strategic foundation
Anyone wanting to develop IT operations away from pure incident reaction towards a forward-looking and structured working method requires clear and resilient ITIL processes. They create the framework to process incidents systematically, implement changes in a controlled manner, and demonstrably increase service quality.
In practice, however, a different picture often emerges: a lack of documentation and unclear roles lead to processes hardly being applied in daily business. The consequences are noticeable – technical inefficiencies, rising costs, and declining user satisfaction.
For a successful ITIL implementation, simply defining processes is not enough. They must be technically supported and anchored in daily work. A centrally maintained CMDB that works closely with the service desk forms an essential building block in this context. In this article, you will receive a practical overview of ITIL processes and learn how to establish functioning ITIL process management step-by-step.
Free trial period of i-doit
Would you like to convince yourself directly of the benefits of i-doit? Then try our software for 30 days for free.
Definition: What are ITIL processes?
 ITIL processes are standardized procedures for managing IT services, based on the IT Infrastructure Library (ITIL). The goal is to make IT services predictable, measurable, and resilient. With ITIL 4, the focus shifted from pure "processes" to holistic "practices". In addition to the process workflow, a practice includes roles, resources, and tools that contribute to co-creating value with the user. This expanded ITIL process definition is central to modern ITIL process management. ITIL 4 defines 34 practices across three categories: General, Service, and Technical Management.
A complete overview of ITIL processes can be overwhelming. Not all 34 practices are immediately relevant for every company. Focus on the core practices that deliver the greatest immediate added value:
Service management practices:
  • Incident Management: The goal is to restore service operations as quickly as possible and keep negative impacts on the business to a minimum. A precisely maintained CMDB helps to immediately recognize dependencies and significantly accelerate root cause analysis.
  • Problem Management: This process revolves around permanently eliminating the root causes of disruptions. Proactive root cause analyses ensure that incidents do not arise in the first place.
  • Change Control: Changes are planned in a controlled manner, evaluated, and completely documented. This reduces the risk of faulty changes and disruptions. An integrated CMDB delivers the information required for a well-founded risk assessment.
  • Service Request Management: Standard requests – such as password resets – run efficiently via clearly defined, ideally automated workflows. This noticeably relieves the service desk.
Technical management practices:
  • IT Asset Management: Tracks all assets across their entire lifecycle, incorporating financial and contractual aspects as well. The CMDB serves as the central database.
  • Deployment Management: Ensures that new or modified services reach the production environment in a controlled manner, coordinating closely with Change and Release Management.
The combination of these practices is the foundation for functioning ITIL process management.
To understand ITIL processes, a look at their evolution helps. While ITIL V3 was rigidly structured along a service lifecycle, ITIL 4 pursues a more flexible, modular approach.
  • The rigid lifecycle model was replaced by the flexible Service Value System.
  • The focus lies on value co-creation rather than pure process workflows.
  • Modern frameworks such as Agile and DevOps are explicitly integrated.
  • The seven Guiding Principles (e.g. "Focus on Value", "Progress Iteratively with Feedback") serve as universal guardrails.
ITIL 4 is more agile and practical. However, the proven process details from ITIL V3 remain valuable as concrete implementation aids for ITIL execution.
ITIL implementation often fails in practice, not in theory. A pragmatic, step-by-step approach is crucial for success.
  1. Analysis and prioritisations: Where are the biggest pain points? Analyse ticket data and conduct interviews. Start with 2–3 core processes such as Incident Management or Change Control.
  2. Clear responsibilities: Define a Process Owner for each process who is responsible for process performance and continuous improvement.
  3. Tool support: A functioning ITIL implementation requires technical tools, particularly a service desk system and a central CMDB as a reliable source of data.
  4. Continuous improvement: Train participants and establish regular reviews based on KPIs. Use the ITIL practice "Continual Improvement" to continuously optimize ITIL process management.
 ITIL process management means not just introducing processes, but monitoring and optimizing them in a continuous loop (Plan-Do-Check-Act). This requires measurable key performance indicators (KPIs).
Process
Example KPIs
Incident-Management
Mean Time to Resolution (MTTR), First Level Resolution Rate
Change Control
Change Success Rate, Number of Emergency Changes
Problem Management
Reduction of recurring incidents
An effective ITIL process management setup is based on a fixed review cadence and a feedback culture that utilizes the knowledge of all participants to optimize ITIL processes.
A central and up-to-date Configuration Management Database (CMDB) is the technical backbone for a successful ITIL implementation. Without it, decisions are based on assumptions rather than facts, which leads to errors in ITIL process management.
  • Incident and Problem Management: It immediately displays affected services and dependencies, drastically shortening diagnosis time and supporting root cause analysis.
  • Change Control: It enables a precise impact analysis by showing which systems and business processes are affected by a change.
  • IT Asset Management: It records the entire asset lifecycle in a central and traceable manner.
The deep integration of the CMDB with the service desk system is the key to efficiency. For example, if a server fails, the system immediately shows which business services are affected, enabling targeted communication. It automates the assignment of tickets to CIs, makes dependencies visible in real time, and ensures audit-proof documentation.
With i-doit as your CMDB, you lay the technical foundation for your ITIL process management. The solution supports ITIL implementation through:
Central documentation and integration: i-doit records the entire IT infrastructure including all dependencies. Through seamless integration with service desk systems (e.g., Zammad, OTRS, iTop), CI data is automatically transferred into tickets, enabling impact analyses directly within the ticket. This creates end-to-end workflows.
Practical process support: Beyond pure documentation, i-doit actively supports you in processes. You can graphically visualize complex dependencies between IT services and the infrastructure. Furthermore, you document changes seamlessly and manage the entire asset lifecycle centrally. Last but not least, i-doit delivers an audit-proof database for compliance verification according to ISO 27001 or DORA, which is crucial for ITIL implementation in regulated industries.
ITIL processes are much more than theoretical models. They offer a practical framework that demonstrably makes IT organisations more efficient. Three factors significantly determine success:
  1. Pragmatic entry point: The greatest benefit arises when the processes that have the biggest effect on stability and productivity are implemented first.
  2. Technical foundation: A centrally maintained CMDB integrated into the service desk is the basis for functional ITIL process management.
  3. Continuous further development: Processes only unfold their value if they are actually lived out, regularly measured, and continuously optimized.
With i-doit as a central CMDB, the necessary foundation is ready to implement ITIL processes transparently, efficiently, and in an audit-proof manner. Put it to the test!
