i-doit Team28. April 2026
Perfectly document cable management in the server racks
7:12
 Table of Contents
1. Cable management in server racks: fundamentals and structured documentation
2. Order in the network cabinet: cable management as the foundation of IT infrastructure
3. What is meant by cable management?
4. Why is cable management in the network cabinet so important?
5. Fundamentals of IT cabling in the server room
6. BSI cabling: secure standards for professional infrastructures
7. Optimising cable management documentation
8. Clean cabling for a stable network
Effective cable management within a server rack is the cornerstone of a structured, high-performance, and maintainable IT infrastructure.
Neatly routed cable connections provide the basis for the smooth operation of network and server components. This is particularly true for modern network cabinets: here, well-thought-out cable routing systems ensure better clarity, increased security, and significantly simplified maintenance.
Conversely, tangled bundles of cables can lead to unwanted interference, difficult troubleshooting, and, in the worst-case scenario, total system failure. Professional cable management reduces these risks and facilitates future expansions or modifications.
In this article, you will learn how to optimally install cables in network and server racks, which accessories have proven most effective, and why structured cable management is decisive for the stability and reliability of your entire IT infrastructure.
In the network cabinet: tidy cable management as the foundation of IT infrastructure
In many organisations, the server room is the heart of IT—and the network cabinet is the centre of the physical infrastructure. Yet, it is still common to encounter cabinets dominated by "cable spaghetti," missing labels, and a complete lack of structure.
Good cable management in the network cabinet is not just an aesthetic win; it is functionally critical. Whether setting up a new environment or optimising existing systems, structured cable management in server racks is indispensable for operational security, performance, and ease of maintenance.
Efficiently document cables and patching
With the i-doit cabling add-on, you maintain a total overview of your cabinet. Discover more here:
Cabling is a vital aspect of infrastructure that extends far beyond the server rack itself. Cable management refers to the meticulous planning, routing, and securing of power, network, and patch cables. It ensures order, reduces clutter, and minimises risks such as tangling or accidental disconnection.
Structured routing simplifies maintenance, saves time during troubleshooting, and improves air circulation within the rack, which in turn aids cooling. By using cable ties, Velcro strips, cable management bars, patch panels, and appropriate power strips, you can achieve professional results.
Additionally, colour coding and labels help to identify connections rapidly, especially in larger or growing IT environments. This ensures the infrastructure remains not only tidy but also future-proof.
Why are cable management and routing so important?
A systematically structured network cabinet offers numerous advantages for both daily operations and future scalability:
  • Clarity and order: Every cable is clearly assigned and follows a logical system. Eliminating tangles saves valuable time during troubleshooting and minimises human error.
  • Optimised airflow: Clean routing prevents "cable jams" that block air movement. This reduces the risk of overheating and extends the lifespan of hardware components.
  • Reduced error rates: Properly secured cables reduce the risk of accidental disconnection or mechanical damage.
  • Easier scalability: New devices or patch panels can be integrated quickly without disturbing existing structures.
  • Efficient documentation: Clear routing makes IT documentation significantly easier. Connections can often be identified at a glance, which is ideal for IT audits.
  • Professional appearance: A tidy rack reflects the professionalism and diligence of the IT department to both customers and auditors.
A good starting point for effective cable management is the careful selection of hardware components and planning tools. It should always be kept in mind that a network cabinet must not only accommodate current loads but also be prepared for future requirements.
Key components for structured management include patch panels, which enable clear and maintainable connections between network components. These are complemented by horizontal and vertical cable managers that organise the cable paths. Velcro ties or "cable combs" help to bundle lines neatly without causing mechanical stress.
By following the guidelines of the Federal Office for Information Security (BSI), you create a robust, documented, and fail-safe IT infrastructure. These recommendations for structured cabling are part of IT-Grundschutz and are particularly relevant for operators of Critical Infrastructure (KRITIS). However, they also serve as an excellent benchmark for standard corporate IT.
Central BSI requirements include:
  • Redundant cabling paths.
  • Minimisation of fire loads.
  • EMC protection through the physical separation of power and data lines.
  • Detailed documentation of all cabling.
  • Physical access security for cable routes.
Aligning your infrastructure with these standards ensures a resilient foundation for maintenance, expansion, and audit readiness.
Professional cable management does not end with the physical installation; only seamless documentation ensures long-term transparency and efficiency. Using i-doit—the central platform for IT documentation—alongside the SM-VIEW Cable add-on, you can extend your network documentation with a vivid, graphical component.
Cable connections and occupied ports are visualised clearly, simplifying daily tasks and providing a traceable overview of existing structures. Furthermore, the add-on allows for detailed recording down to the individual core or fibre level. This makes i-doit a vital tool for audit-proof, future-oriented management in both small IT environments and large data centres.
Document cables efficiently
Technical documentation often focuses on servers and network devices while neglecting the cables. Yet, cabling is crucial for error analysis and performance optimisation. Learn how to document your cabling efficiently with i-doit.
A tidy network cabinet is more than just a visual "calling card" for the IT team. It symbolises the professionalism, efficiency, and reliability of the entire department.
Thoughtful cable management ensures a clear structure for all connections—from power supply to network infrastructure. When established standards like the BSI recommendations for structured cabling are followed, it significantly increases operational resilience and IT compliance. Combined with digital, centrally maintained documentation, you create a transparent and maintainable IT landscape.
Would you like to map your network cabling and take your cable management to the next level? We would be happy to show you how i-doit can support you.
