Using IP scanners: network analysis provides security
1. Efficient network analysis with IP scanners
2. What is an IP scanner?
3. How does an IP scanner work?
4. Four good reasons for regular network scans
5. Advanced technologies in IP scanning
6. IT security functions of IP scanners
7. Best practices for the secure use of network IP scanners
8. Greater security through transparency in IT networks
With the rising number of IoT devices and shadow IT, companies are increasingly discovering unauthorised devices or software in their corporate network. These "blind spots" often open the door to your systems for cyberattackers unnoticed—and thus represent a significant security risk. At the same time, requirements are increasing for companies to seamlessly document their IT infrastructure and comply with regulatory specifications such as GDPR or ISO 27001.
This is where IP scanners come into play: these tools automatically record all devices on the network. They help you to prevent unauthorised access and efficiently prepare for audits. A high-performance IP scanner creates transparency across your entire network structure and thus actively supports you in the security and optimisation of your IT environment.
In this article, you will learn what exactly IP scanners are, how they work, and what benefits they bring to your company.
An IP scanner is an indispensable tool for IT administrators: it analyses the network and provides detailed information about all connected devices. The scanner scans a defined range of IP addresses and detects:
- active devices
- open ports
- operating systems
- device names
- MAC addresses
- type of network connection
To analyse, the tool uses protocols such as ICMP, TCP, or UDP—and even creates a visual network mapping if required, which clearly displays the entire infrastructure. However, an IP scanner does not only help with recording the network structure, but also with tracking down vulnerabilities. For example, you can detect open ports or outdated software versions.
Private users also benefit from greater transparency in their network environment. Important note: scanning should only take place within your own network. Unauthorised scanning of external systems is legally prohibited and can have criminal consequences.
Main categories of IP scanners
For better classification, IP scanners are typically differentiated into two types:
- Basic scanners: They record fundamental information about connected devices and open ports.
- Advanced solutions: They offer additional functions such as anomaly detection and detailed protocol analysis.
Well-known tools include Nmap, Angry IP Scanner, or Advanced IP Scanner, which offer different functional scopes and interfaces.
Important functions of an IP scanner
A modern IP scanning tool offers a variety of useful functions. The following belong to the central building blocks of any effective network analysis:
- Device discovery: Identification of active devices on the network (e.g. PCs, smartphones, printers, IoT devices).
- Port scanning: Review of open ports to uncover potential security vulnerabilities.
- Network inventory: Generation of an overview of the network structure.
- Real-time monitoring: Continuous monitoring for changes.
Tip: With the i-doitCMDB, the results can be seamlessly integrated into the IT documentation.
An IP scanner sends network packets to IP addresses within a defined range. Depending on the type of response or the absence thereof, it can be determined whether a device is active. Information about open ports, services, or operating systems is obtained by analysing the responses.
The most important technical procedures at a glance:
- Ping scanning: ICMP echo requests to identify active IPs.
- Port scanning: TCP/UDP packets to detect open or filtered ports.
- OS detection: Analysis of response patterns to determine the operating system.
Note: The MAC address can only be recorded in local networks (Layer 2) via ARP, not in routed environments.
This information provides administrators with a comprehensive picture of the network environment and helps to detect security gaps early on.
Typical workflow of an IP scan
A standard scan process usually runs in the following steps:
- Define the IP address range
- Send network packets (e.g. ICMP, TCP)
- Analyse responses
- Generate report and document results
Areas of application for IP scanners
IP scanners can do far more than just detect devices. They are suitable, among other things, for the following task areas:
- Security analyses: Tracking down unauthorised or insecure systems.
- Network optimisation: Detecting bottlenecks by analysing IP address distribution.
- Troubleshooting: Identification of configuration errors or unreachable devices.
- Planning and expansion: Supporting the planning of network infrastructure.
Regular network scans offer numerous advantages. The following aspects are particularly noteworthy:
- Inventory on the network: Complete documentation of all devices.
- Security management: Detection of open ports, unknown devices, and outdated software.
- Performance analysis: Optimisation through targeted data analysis.
- Troubleshooting: Rapid localisation of problems.
During regular network analyses, i-doit and JDisc work together perfectly. The appropriate interface is already firmly integrated into i-doit.
Tip: With i-doit discovery, you learn which components your IT infrastructure consists of. This gives you an up-to-date IT inventory tailored to your needs and ensures you never pay too much again. All relevant information can be dynamically uploaded to i-doit.
Import data easily: everything about our add-on
Learn more about JDisc functions and integration into the i-doit CMDB.
Depending on requirements, different technical approaches are available. These can be differentiated as follows:
- Agent-based scanners: Software on target systems provides detailed data.
- Agentless scanners: Gather information via protocols such as SNMP, WMI, or SSH.
- Passive scanners: Analyse existing network traffic without active scanning (e.g. Wireshark).
- Hybrid scanners: Combination of all methods for complete network discovery.
Modern scanners offer numerous functions to improve network security. Particularly helpful are:
- Detection of shadow IT and unauthorised devices.
- Tracking down outdated software (End-of-Life).
- Analysis of insecure protocols or encryption methods.
What should you look for during selection? The selection of the matching tool depends heavily on the IT landscape. Important criteria include:
- Supported protocols and networks.
- Accuracy in asset discovery.
- Integration capability with CMDB or security platforms.
- Usability and automation.
- Costs and licensing model.
A few tools have proven particularly successful on the market. These include:
- Nmap: Comprehensive open-source solution, ideal for security experts.
- Advanced IP Scanner: User-friendly, particularly suitable for Windows networks.
- Angry IP Scanner: Cross-platform and fast.
- SolarWinds IP Address Manager: Commercial tool with strong IPAM functionality.
To use IP scanners safely and efficiently, administrators should observe and establish the following routines:
- Carry out scans regularly.
- Scan outside operating hours.
- Purposefully evaluate and document results.
- Obtain legal permissions.
- Ensure integration into IT systems like the i-doit CMDB.
In addition to proven procedures, a look into the future is also worthwhile. Artificial intelligence brings new trends for IP scanning. Exciting and expected developments include:
- AI-supported anomaly detection for faster responses.
- Cloud-based scanners for greater scalability.
- IoT focus: specialised discovery for smart devices.
- Automation: automatic isolation of suspicious systems.
- Visualisation: graphical network plans for better orientation.
IP scanners are a central tool for network analysis and IT security. They support administrators in managing networks efficiently, detecting vulnerabilities early on, and purposefully optimising system performance. Thus, IP scanners make a valuable contribution to a secure and transparent IT infrastructure.
With i-doit, you transfer scan results directly into a central IT documentation system. We would be happy to show you how you can optimally use IP scanners in combination with i-doit for your company—or test i-doit without obligation with full functionality. Request your free demo or contact us directly.
