Project documentation: examples & template
1. Project documentation: examples, IT project documentation and template
2. What does "documentation of a project" mean?
3. Documentation of a project in IT: core elements
4. Examples of project documentation: two typical scenarios
5. Creating project documentation: template for IT project documentation
6. IT project documentation with i-doit
7. Documentation of a project is indispensable
Project documentation: examples for IT project documentation and template
Very few IT teams enjoy dealing with administrative tasks. Yet the long-term success of a project stands and falls with its documentation. Only when goals, architectural decisions, and technical specifics are clearly documented can coordination processes be accelerated, costly misunderstandings be avoided, and changes be tracked in an audit-proof manner.
In practice, two worlds intertwine: administrative project management documentation and technical IT project documentation. The challenge lies in intelligently interlocking both areas. This requires clearly defined responsibilities, a consistent data basis, as well as an up-to-date overview of assets, configurations, contracts, and suppliers.
This article provides you with a blueprint for the documentation of a project. Using concrete examples and a template for IT project documentation, we will show you how to place your venture on a solid foundation right from the start.
Free trial period of i-doit
Would you like to convince yourself directly of the benefits of i-doit? Then try our software for 30 days for free.
The documentation of a project is the organised recording of all relevant information: from the idea to completion. This includes the goal, scope, requirements, time and budget planning, risks, decisions, changes, and sign-offs.
An IT project documentation additionally maps operational reality: a complex web of systems, services, applications, and network components. Crucial here are the technical details, responsibilities at the asset level, as well as the link to contracts and suppliers.
This structural information is also the focus of a Configuration Management Database (CMDB) like i-doit. It records Configuration Items (CIs) and their dependencies in bidirectional and versioned relationships, thereby creating an operational Single Source of Truth. The result is a dynamic knowledge base for precise impact analyses, well-founded change decisions, and a seamless, low-risk transition into regular operations.
Why is the documentation of a project important?
Single Source of Truth: A shared data basis ensures that all stakeholders work with the same configuration and asset data. This minimises errors and accelerates technical coordination processes.
Complete audit trail: All decisions and configuration changes are stored in the database and assigned to responsibilities. This makes them traceable over the long term.
Proactive risk management: Dependencies between services, applications, and infrastructure components are made visible. This facilitates risk analysis.
Seamless transition into IT operations: Consistent project management documentation ensures operational clarity from day one, shortening onboarding time as well as the Mean Time to Resolution (MTTR) in the event of disruptions.
Guaranteed compliance: The versioned recording of all changes and configurations makes it easier to fulfil guidelines and standards (e.g. ISO 27001, BSI IT-Grundschutz).
Project management documentation: systematic approach
At the organisational level, project management documentation bundles various instruments. These include the project charter, which defines the mandate and goals, detailed plans for scope, deadlines, and budget, as well as established processes for risk, issue, and change management.
For IT operations and technical implementation, however, this perspective falls short. Here, the link between management specifications and components and services must also be taken into account. In this context, the following questions are also relevant for project management documentation:
Scope: Which systems, applications, and infrastructure assets are affected?
Change: Which CI is being modified and what dependencies exist?
Risk: Which services are endangered by this risk?
Responsibility: Who is the technical contact person for this asset or service?
IT project documentation: connecting technology and IT operations
This layer goes beyond pure project planning and models the future IT service in all its technical facets. The core elements of IT project documentation include:
CMDB foundation: All relevant Configuration Items, from servers and VMs to applications, network components, and locations.
Logical and physical topology: A detailed representation of the network and IP structure, including subnets, VLANs, DNS/DHCP configurations, and routing tables.
Security & Compliance by Design: This includes permission concepts, the classification of protection requirements, as well as hardening measures and audit logs.
Operational operating parameters: All operationally relevant specifications such as monitoring thresholds, backup cycles, maintenance windows, and performance KPIs.
The goal is a consistent overall picture: project and IT operations interlock seamlessly, the go-live proceeds according to plan, and subsequent maintenance takes place without surprises. Relationships between objects are documented in a versioned manner, so that impact analyses within the framework of changes are possible at any time.
Contracts, suppliers, responsible persons
Perhaps the most important component of an actionable IT documentation is the direct linking of assets and services with the corresponding organisational and commercial data. Therefore, the following information should be stored at the respective Configuration Item in the CMDB:
Contractual data: Maintenance contracts, licence information, guaranteed Service Level Agreements, terms, and notice periods.
Suppliers & partners: Responsible implementation partners, service providers, and direct support contacts.
Responsibilities: A matrix ranging from the technical contact person to the product owner up to the final operational responsibility.
In the event of an incident, this eliminates the time-consuming search for responsibilities or contract details. A glance at the CI is sufficient to transparently trace the entire escalation chain (SLA/OLA) and find the right contact persons.
Step-by-step to IT documentation
Perfect for beginners: learn how to optimally introduce IT documentation into your organisation. In the i-doit whitepaper, you will find a common thread that guides you step-by-step to success.
The following examples of project documentation in IT show two typical scenarios from practice.
1. Introduction of a new business application
Every new business application also includes an additional IT service. The documentation forms its blueprint. Architecture diagrams and data flow charts map the dependencies between application components, databases, and API interfaces. A RACI matrix creates responsibilities, while a detailed migration and cutover plan safeguards the transition from the project into regular operations.
Technical dimension: The documentation records the entire service model: from provisioned servers and VMs to database schemas, network segments, and firewall rules, right up to monitoring parameters and permission concepts.
Organisational dimension: Responsibilities, the defined support model (1st/2nd/3rd level), the linked licence and maintenance contracts, as well as the contact details of the implementation partner are stored directly at the service.
Operational result: A finished IT service. Alongside the application, operations receives a complete package consisting of an operating and emergency manual, a fully configured monitoring system, and SLAs.
2. Relocation of the data centre
A data centre relocation is a complex operation whose success depends on a meticulously maintained Single Source of Truth. This contains all physical and logical details: asset lists with serial numbers, rack occupancy plans, detailed cabling and port assignments, meticulously planned maintenance windows, fallback scenarios, and restart plans.
Technical dimension: The documentation encompasses the assignment of systems to new racks and locations, detailed network and power paths (PDU/UPS), adjustments to storage/SAN zoning and firewall ACLs, as well as all updates for IPAM, DNS, and DHCP.
Organisational dimension: This layer maps the communication and escalation chains. This includes internal and external contact lists, a detailed schedule with all service providers, change freezes, as well as acceptance checklists for recommissioning.
Operational result: A controlled recommissioning verified by logs. The CMDB reflects the new actual state 1:1, and responsibilities in the event of a disruption are clearly defined.
When you create project documentation, the following template for IT project documentation helps you with a structured approach. It relies on a lean structure: quick to maintain, clear in responsibility, and connectable for technical details. This keeps the project documentation clear, from kick-off to handover.
Project charter: What are the goal and the scope?
Requirements and acceptance criteria: What should the system achieve and how will it be measured?
Resource planning: Binding time and budget plans.
Architecture blueprint: The target architecture of the system landscape.
CMDB model: All affected asset classes and dependencies.
Accountability matrix (RACI): Who is responsible for what?
Risk, issue & change log: A protocol of all risks, problems, and changes.
Contract and supplier portfolio: All contracts, terms, and contact persons.
Quality assurance & handover: Test plans, acceptance protocols, and the final protocol of the operational handover.
Operating and emergency manual: Information base for 1st- and 2nd-level support.
Lessons learned and final report: The knowledge base for future projects.
Practical tip: Keep your project documentation modular. Attach crucial artifacts like acceptance protocols or firewall releases directly to the relevant CI in the CMDB. This makes searching in an emergency unnecessary.
With i-doit, the documentation of an IT project becomes dynamic. Instead of managing information in isolated documents, all project data is bound directly to the affected assets and services in the CMDB.
Central documentation: All project-related resources are modelled as Configuration Items with their dependencies. i-doit answers the question "Which systems are affected by a change?" with a precise impact analysis.
Clear accountability: Responsibilities, RACI roles, and technical contact persons are stored directly at the respective CI in i-doit. In the event of a disruption, searching through contact lists is eliminated.
Integrated contract and supplier management: Licence contracts, maintenance agreements, and SLAs are no longer separate documents, but attributes of the affected CIs. Linking suppliers with systems enables forward-looking vendor management.
Automated data consistency as a foundation: All project participants work on an up-to-date data basis. By integrating discovery and monitoring tools, the alignment between the target concept and the actual state is automated.
Audit-proof compliance and documentation: Through seamless versioning, i-doit makes the documentation audit-proof. Operating and system manuals are generated as a standardised, up-to-date report from the CMDB data.
Good IT project documentation is the best insurance against operational hecticness and unforeseen outages. It makes complex projects transparent, dependencies visible, and decisions traceable. When you consistently link technical assets, responsibilities, and contracts, you prevent information silos and ensure a seamless handover to IT operations.
With a centrally maintained CMDB like i-doit, this discipline becomes a routine. You create a consistent data basis that supports everyone involved, from the project manager to the service desk. With clear project management documentation, you ensure that projects leave behind an efficiently maintainable and at all times auditable solution.
See for yourself how you always have everything under control with i-doit and optimally support your IT project documentation:
