Incident management: Process & incident response tools
1. Incident management: Understanding the process and using incident response tools
2. What is incident management? Definition and fundamentals
3. Why is incident management a must for companies?
4. The incident management process: Step by step
5. Incident response tools: Software for effective IT incident management
6. The role of the CMDB in IT incident management
7. INDART Professional® or i-doit Suite+ Emergency: Emergency planning and incident management
8. Incident management: A central building block for stable IT operations
Operational disruptions, for example in IT, not only impair ongoing operations, but often also cause significant costs. Siemens' "True Cost of Downtime Report 2024" showed over two years ago: Every year, the 500 largest companies lose around $1.4 trillion due to unplanned downtime. That represents 11% of their annual revenue. In 2024, the average cost per minute stood at $14,056, and in large enterprises, even $23,750. Such figures illustrate: Without effective incident management, companies risk substantial financial and operational damage.
And an important point to add: One must not forget that the cost of downtime is not limited to, for instance, lost production during the outage. The actual economic damage stems from a cascade of lost production, staffing and restart costs, delivery delays, contractual penalties, and potential customer churn.
With a clearly defined incident management process, responsible teams detect disruptions early, prioritize them correctly, and resolve problems significantly faster. Crucial in this regard are not only technical measures, but also clear responsibilities, documented processes, and the use of suitable incident response tools. Learn how to successfully establish incident management in your company and why up-to-date, well-structured IT documentation is one of the essential foundations.
Incident management is the systematic process for handling unplanned interruptions or reductions in the quality of IT services or processes. In some contexts, it is also referred to as "IT disruption management." According to ITIL 4, an incident is defined as any event that disrupts the normal operation of a service or impairs its quality – whether it involves an isolated user login problem or an enterprise-wide network outage.
The primary goal of incident management is to restore normal service operation as quickly as possible while minimizing negative impacts on the business. Unlike problem management, incident management does not focus on root-cause analysis. Instead, it is aimed at rapidly restoring service functionality.
Free live demo of incident management solutions
CONTECHNET is now a full part of i-doit GmbH. Experience software solutions for emergency planning, BCM, ISMS, and data protection in a remote live demo.
Why is incident management a must for companies and every other organization?
The more business processes depend on digital systems, the more critical reliable IT incident management becomes. Companies today rely on dependable IT services; any disruption can directly impact productivity, revenue, and customer satisfaction.
A structured incident management approach brings numerous benefits:
Minimized downtime: Rapid responses and clear escalation paths significantly reduce the duration of disruptions.
Improved service quality: Consistent processes ensure consistently high service levels.
Increased transparency: Documented incidents create traceability and enable data-driven decision-making.
Optimized resource utilization: Prioritization based on business impact prevents resource waste.
Compliance with service level agreements (SLAs): Structured processes help meet agreed SLAs.
Continuous improvement: Incident data yields valuable insights for optimizations and preventive measures.
An effective incident management process follows a structured workflow. It ensures that disruptions are processed systematically and transparently:
1. Incident detection and logging
Incidents reach IT through various channels, such as service desk reports, monitoring systems, or automatically triggered alerts. Every incident is initially logged and enriched with all essential information (timestamp, affected services, observed symptoms, and potential impacts). Based on this, prioritization according to ITIL takes place: The combination of the extent of impact and urgency determines the final priority level.
2. Categorization and prioritization
In the next step, an incident is assigned to an appropriate category, such as hardware, software, or network. This is followed by prioritization, which involves two criteria: How quickly must the incident be resolved (urgency)? And how significant is the impact on users or services (impact)? Both values yield the final priority with which the IT team processes the incident.
Typical priority levels include:
- Critical: Enterprise-wide outage of critical services.
- High: Multiple users or key functions affected.
- Medium: Individual users or non-critical services affected.
- Low: Minimal impact, workaround available.
3. Diagnosis and investigation
The support team analyzes the incident and attempts to identify the root cause. This is where the value of a well-maintained Configuration Management Database (CMDB) for the incident management process becomes clear: It immediately delivers information on affected assets, dependencies, and configurations.
4. Escalation (if required)
If the incident cannot be resolved by first-level support, it is escalated to specialized teams. A distinction is made between functional escalation (to subject matter experts) and hierarchical escalation (to management for critical incidents).
5. Resolution and recovery
The responsible team implements a solution or workaround. The goal is to restore service operation as quickly as possible. The resolution is documented and the user is informed. Key performance indicators such as MTTR (Mean Time to Restore Service) or MTTA (Mean Time to Acknowledge) help make process quality measurable.
6. Closure and documentation
Following successful resolution, the incident is closed. Complete documentation is essential: What was the cause? What solution was implemented? How long did remediation take? The collected data helps you categorize future incidents faster while providing valuable input for the continuous optimization of your processes.
Incident management software automates many process steps and improves collaboration between teams. Today, incident response tools are indispensable assets for IT teams that must respond to disruptions quickly and in a coordinated manner. The right incident management software combines automation with intelligent escalation mechanisms, ensuring that no critical incident goes unnoticed.
Incident response tools differ from simple ticketing systems through their ability to automatically prioritize critical incidents and involve the right experts at the right time. Especially in complex IT infrastructures, this capability is crucial for achieving rapid response times.
A CMDB such asi-doit or i-doit up forms a central success factor for efficient IT incident management. Such a platform contains detailed information about all IT assets (Configuration Items) and their interrelationships. It enables faster diagnosis by providing immediate context regarding affected assets and their dependencies.
Through impact analysis, documented dependencies reveal which services or users might be affected by an incident. Tickets can be linked directly to assets in the CMDB and enriched with relevant data, accelerating resolution. This makes the entire incident history visible within the IT documentation, while prioritization becomes more precise as the business impact of individual components is directly evident.
To prevent the flow of information between the CMDB and ticketing system from becoming an additional bottleneck, both systems should be tightly integrated. For this reason, i-doit offers native interfaces to ticketing tools such as Zammad, OTOBO, or JIRA.
INDART Professional® or i-doit Suite+ Emergency: Comprehensive emergency planning and incident management
For companies and every other type of organization seeking to extend their incident management with structured emergency planning and restart management, INDART Professional® from the i-doit GRC Suite or the Suite+ Emergency feature package from the i-doit GRC Suite+ offer comprehensive solutions. Following the merger of the former companies CONTECHNET Deutschland GmbH and synetics GmbH into i-doit GmbH, along with PATCH MANAGER, which has been part of the i-doit group since January 2026, a steadily growing software platform product has emerged. It delivers greater clarity and transparency across countless use cases in any organization, accelerates workflows, reduces costs, and fulfills compliance verification requirements at the touch of a button. For this specific case, the software combines specialized emergency management capabilities with clearly structured IT documentation, assisting incident management by centrally providing all information relevant to crisis and emergency situations.
Here is how both INDART Professional® and i-doit Suite+ Emergency support your incident management in practice:
Seamless documentation: Incidents and emergency scenarios are linked to affected assets, services, and business processes.
Fast identification: Thanks to underlying IT documentation and CMDB integration, affected IT components and services become visible quickly.
Efficient processing: Integration with existing service desk or ITSM solutions enables seamless workflows in IT incident and emergency management.
SLA and recovery support: Automated monitoring, defined recovery objectives, and escalation mechanisms help maintain compliance with SLAs and emergency mandates.
Structured IT emergency planning: Checklists, emergency manuals, and actionable instructions guide teams through critical situations, from initial response to the controlled restart of IT services.
In an increasingly digitized business world, outages not only lead to substantial costs, but also undermine user satisfaction and trust in your services. A clearly structured incident management process is therefore one of the cornerstones of stable IT operations.
Rely on defined workflows, suitable incident management software, and neatly integrated IT documentation. In doing so, you reduce response and recovery times, lower operational costs, and sustainably increase service quality.
Crucial above all is the interplay between IT incident management, IT emergency planning, and a CMDB. While incident management swiftly resolves acute disruptions, emergency planning ensures that your organization remains operational even in critical situations.
INDART Professional® and i-doit Suite+ Emergency effectively connect both domains: Disruptions are logged in a structured manner, dependencies are transparently documented, and restart processes are clearly defined. This creates a resilient IT landscape that functions reliably even in emergencies, strengthening long-term resilience, continuity, and trust in your IT services.
Schedule your personal demo appointment now to experience INDART Professional® and i-doit Suite+ Emergency firsthand:
Book an appointment for a live demo of i-doit now
Experience i-doit in action: In an individual live demo, our experts will show you how to effortlessly structure your IT documentation and CMDB. Over 2,000 customers already rely on our solution for their digital resilience.
