i-doit Add-on Maintenance
Maintenance of your IT components requires not only good timing, but also on-time documentation. With this add-on you simplify a lot.
Functions
- Planning of one-time and recurring maintenance schedules
- Relations to any IT asset and Configuration Item
- Calendar view for future maintenance windows
- Documentation of maintenance results
Manufacturer
Description
Coordinate maintenance schedules and document all changes in a central place
With this add-on you plan your one-time and recurring maintenance schedules which are then shown in your calendar view. Automatic notifications can be added to you schedules. The maintenance dates are linked with the impacted objects which enables the team to access the entire documentation and the history of the maintained device immediately.
If there is currently a maintenance window the respective status is shown in the CMDB and visible for everyone. The results of the maintenance can be documented in dedicated fields, a note on the completed maintenance is also added to the logs of related objects.
Who do we recommend this add-on for?
Organizations, which deal with the coordination of maintenance and efficient execution of maintenance windows, obtain organizational support with the Maintenance add-on.
Pricing & support
This add-on is available free of charge. Support is covered by the i-doit Basic support option.
Do you have any questions on this add-on?
If you need more information about this add-on, please send us a message. We will contact you in a timely manner.
